New Owner 425
/ New Owner 425 #21
My brush hog is directly driven off of the hydraulic motor. It was purchased in 2001.
/ New Owner 425 #22
Actually, isn't there a spindle on the TOP of the brush hog that needs greasing?
-Rob /forums/images/graemlins/grin.gif
/ New Owner 425
I was unable to find a zerk fitting so I called the factory. They responded, "No zerk because it is the new model with direct drive." Don't know what "new" means, MossRoads is a 2001. Mine is 2004. In any event, the motor casting mounts directly on the deck. ???
/ New Owner 425 #24
I thought I saw where someone replaced the hyd motor on their mower, and even tough it is direct driven, it still turns a spindle which has at least two bearings. If the bearings are not sealed, it will have to be greased about every 8 to 15 hours.
Please correct me if your hyd motor turns that swing blade directly without going through a spindle and bearing assembly
/ New Owner 425 #25
Here's some pictures of my brush hog disassembled.
Picture of the shaft sticking up through the deck. 3 of 5 bolts installed to hold the hub underneath. The bracket for the motor and the grease zerk at the bottom left in the shadows.
Picture 2 all 5 bolts installed. Arrow pointing out grease zerk.
Picture 3 shows bottom half of love-joy connector on shaft. Rubber star sitting on top of deck waiting to be installed.
Picture 4 rubber star installed.
Picture 5 motor installed onto shaft. It had the other half of the lovejoy connector on the motor shaft already. Motor mounting bolts not installed yet.
Hope this clearly shows what I have. /forums/images/graemlins/wink.gif Is the new one different?
2012 Allmand Nite-Lite Pro II 8KW Towable Light Tower (A64194)
2012 Allmand...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A64553)
2023 John Deere...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A64553)
2025 Mower King...
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
2016 Chevrolet Tahoe SUV (A64194)
2016 Chevrolet...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
