New Forum Thread
/ New Forum Thread #41
-- INDEX --
I've used other forums with this software and it really is quite nice once the bugs get worked out. However, it has always bothered me that there is no way to return to the previous level by clicking a link on the bottom of the page. This was one of the things I really liked about TBN.
Example -- After scrolling down to the bottom of the thread and reading the last post, you used to be able to click "Return to Index" (or something similar) to return to the next level up (list of threads).
Other than that, looks like you guys are spending some huge time here cleaning things up a bit. I must say, I admire your hard work. It's not an easy job to please everyone!
/ New Forum Thread
rox said:
Why do I see the HTML Mark Up instead of the text?
Like this for example
"</font><font color="blue" class="small">("
Because the forums are set to now allow HTML, and all the old markup came in as HTML. So we have to run a process to filter/change it all.
/ New Forum Thread #43
back ground color
I know it varies with individual monitors and how they are set, but I think it would be easier to read if the pink (?) background were a little darker.
/ New Forum Thread #44
The HTML code is currently turned OFF :eek: See the option box in the lower left corner of the screen?
/ New Forum Thread #45
There are options that the administrators can turn on that will allow us users to alter the appearance. Currently those options seem to be turned off. But I do agree with you, the screens are pretty low contrast right now.
/ New Forum Thread #46
I think that feature is still there - it's called Forum Jump and it's at the bottom right of the page.:confused:
/ New Forum Thread #47
Existing signatures (those existing pre-update) are not being displayed. They are being displayed for new posts, however.
/ New Forum Thread
Could you post a screen shot of what you see?
/ New Forum Thread #50
double
maybe a stupid question. but I get the post repeated.there are two of every post. I am set to the Linear setting. If that makes a difference.
/ New Forum Thread
EVERY thread or just some? There are some that we are aware of, that will be removed later.
/ New Forum Thread #52
Back on
/ New Forum Thread #53
When I am at the Discussion Forum main screen and I click the IE6 Refresh button, the page reloads/refreshes but the forums that were previously marked as having unread messages are still marked as such even though I already read all the posts in them. I tried all the IE6 settings for page refresh and the problem did not change.
/ New Forum Thread #54
I think it's a lot cleaner look. I like it............Good job.
/ New Forum Thread #55
It looks like the feature that keeps track of unread posts is not updating. If I completely exit from IE6 and then restart and go to TBN, the forums that indicate unread threads are always the same as they were when I started to use TBN a few hours ago. Is this me or TBN? It also says my last visit was at 3:39 which it isn't. It should be 5:29 EDT.
/ New Forum Thread #56
Well,
All the questions I had have been answered in this thread except....
Do you have to fill out the "Title:" box when replying?
Does it become necessary to track where you've posted or something?
This is new???:confused:
/ New Forum Thread #57
What is the difference between the Avatar Edit and the Profile Picture Edit? I up loaded one on avatar and it shows up on my posts now. Also up loaded a different one for profile but only the avatar pic shows up when I check my profile??
Thanks,
Rob-
/ New Forum Thread #59
The part that I like the least so far is that there is no timed view. I have always really like the 12 and 24 hour view. I bet that that won't work with this new setup?
/ New Forum Thread
3RRL said:
How does the "report bad post" icon work? I noticed the icon is not on my posts here?
Report bad post would be if a post needs moderator attention.
User pictures are simply pictures shown on your profile. Avatars are what show with your posts.
You don't have to enter a secondary title.
PALLET OF 51 X 41 X16 BRASS WEAR RINGS (A67714)
PALLET OF 51 X 41...
2007 Sterling L9500 Tri-Axle Dump Truck (A66736)
2007 Sterling...
2011 Nissan Murano SUV (A64557)
2011 Nissan Murano...
2025 Pallet of Miscellaneous Duplex Polyester Webbing Slings (A66734)
2025 Pallet of...
2013 HAULMARK ENCLOSED UTILITY TRAILER (A67714)
2013 HAULMARK...
2019 KENWORTH T680 (A67714)
2019 KENWORTH T680...
