new Doo Little
/ new Doo Little
I buy it by the roll from Amazoie and I think I paid $14 for 150ft last time. Over the years I have got reflective materials from the HW store and figured out it was worthless. DOT certified decals work and its cost is worth not having an accident.
/ new Doo Little
DooLittle at work today for the 1st time ever. :D
/ new Doo Little
I'm adding 10,000lbs tie-down D rings because the ones DoodLittle added are in poor positions for 6x6 atv moving. Will post pics in time. Although we do like this trailer. (y)
/ new Doo Little
I added 6 extra D-rings to this trailer today. The ones that Doolittle added were in from the corners and not good for tying down our 6x6 and they only added 4 of them. Not sure why they'd put them so far in from the corners as seen in the pic.
Now the angle is a bit better.
More added to the front.
Extra ones in the middle.
/ new Doo Little #27
Nice trailer! Never saw one like that before with the low steel sides. I have a 12ft landscape single axle with brakes and a large gear basket in front. It's my go to quad trailer.
/ new Doo Little
Ya, it's not been perfect but still handy as heck. Far better in general than the B Tex one it replaced.
/ new Doo Little
I added more d-rings to the box sides today and a attachment location for the hitch pin. The nice one seen here came with trailer but no place to add it so today I added the white aluminum plate to zip tie it on.
/ new Doo Little #30
Not to criticize your work, but since the top rail is only bent material, not a tube, aren't you concerned about bending the top rail if you pull a strap or chain up tight?
Maybe a couple of triangle plates welded in on the outside below the D-rings to add some support.
Just my $.02.
/ new Doo Little #31
Just my $.02.
Tend to agree, but for such a little machine, it would probably handle it without bending.
/ new Doo Little
These just added aluminum D-rings located on the sidewalls are to hold slash loads down. Any heavy loads, like our 6x6 need to be held by the main d-rings near the floor and seen in this pic.
/ new Doo Little #33
Drings are awesome add ons to any trailer, especially if you buy them in quantity they are pretty cheap. I had some lying around awhile back and welded 12 to my single axle trailer, I had the unfortunate benefit of using it for a year before the rings however in doing so I was able to figure out to put them where I needed them most. I don't mind welding stuff that can be drilled and bolted, weldings stronger imo and over the years if something welded breaks I've became a proficient wafer wheel and flap disk operater lol.
/ new Doo Little #35
ArylA, is that white stuff "here to stay"? Just got a dusting here last night. Jon
/ new Doo Little
We are installing a cheap little "slide in" crane to back of this trailer asap. Loading or unloading implements that don't like to slide bits.
CAT 963C GP Bucket (A68134)
CAT 963C GP Bucket...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
2014 Dodge Charger Sedan (A66738)
2014 Dodge Charger...
2025 48in. Farm Jack (A66734)
2025 48in. Farm...
2002 PETERBILT 330 WATER TRUCK (A67714)
2002 PETERBILT 330...
220 VOLT 6IN SUBMERSIBLE PUMP (A67714)
220 VOLT 6IN...
