new Doo Little
/ new Doo Little
I buy it by the roll from Amazoie and I think I paid $14 for 150ft last time. Over the years I have got reflective materials from the HW store and figured out it was worthless. DOT certified decals work and its cost is worth not having an accident.
/ new Doo Little
DooLittle at work today for the 1st time ever. :D
/ new Doo Little
I'm adding 10,000lbs tie-down D rings because the ones DoodLittle added are in poor positions for 6x6 atv moving. Will post pics in time. Although we do like this trailer. (y)
/ new Doo Little
I added 6 extra D-rings to this trailer today. The ones that Doolittle added were in from the corners and not good for tying down our 6x6 and they only added 4 of them. Not sure why they'd put them so far in from the corners as seen in the pic.
Now the angle is a bit better.
More added to the front.
Extra ones in the middle.
/ new Doo Little #27
Nice trailer! Never saw one like that before with the low steel sides. I have a 12ft landscape single axle with brakes and a large gear basket in front. It's my go to quad trailer.
/ new Doo Little
Ya, it's not been perfect but still handy as heck. Far better in general than the B Tex one it replaced.
/ new Doo Little
I added more d-rings to the box sides today and a attachment location for the hitch pin. The nice one seen here came with trailer but no place to add it so today I added the white aluminum plate to zip tie it on.
/ new Doo Little #30
Not to criticize your work, but since the top rail is only bent material, not a tube, aren't you concerned about bending the top rail if you pull a strap or chain up tight?
Maybe a couple of triangle plates welded in on the outside below the D-rings to add some support.
Just my $.02.
/ new Doo Little #31
Just my $.02.
Tend to agree, but for such a little machine, it would probably handle it without bending.
/ new Doo Little
These just added aluminum D-rings located on the sidewalls are to hold slash loads down. Any heavy loads, like our 6x6 need to be held by the main d-rings near the floor and seen in this pic.
/ new Doo Little #33
Drings are awesome add ons to any trailer, especially if you buy them in quantity they are pretty cheap. I had some lying around awhile back and welded 12 to my single axle trailer, I had the unfortunate benefit of using it for a year before the rings however in doing so I was able to figure out to put them where I needed them most. I don't mind welding stuff that can be drilled and bolted, weldings stronger imo and over the years if something welded breaks I've became a proficient wafer wheel and flap disk operater lol.
/ new Doo Little #35
ArylA, is that white stuff "here to stay"? Just got a dusting here last night. Jon
/ new Doo Little
We are installing a cheap little "slide in" crane to back of this trailer asap. Loading or unloading implements that don't like to slide bits.
FLUID PUMP (A67714)
FLUID PUMP (A67714)
Vanguard V215-PH 4WD Articulating Heavy Haul Agricultural Tractor (A66734)
Vanguard V215-PH...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
KOMATSU D51PXI-24 CRAWLER DOZER (A65053)
KOMATSU D51PXI-24...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
