New BBQ pit in the making
   / New BBQ pit in the making #1
MutzFarm
Texas
Kubota M62
Cant wait. Accumulated the pipe and trailer years ago. That probably half the cost.
Fire box and cook chamber will be made out of the pipe which is 24" in diameter and 1/2" wall. The firebox will be 30" long and the cook chamber is about 80" long.
I will also make a smoker on the end of the cook chamber. I am thinking something around 3'x3'x3'.
Probably wont get really going till after January.
I'll try to throw up some pictures every now and again.
   / New BBQ pit in the making #2
I’m looking forward to following this project.
   / New BBQ pit in the making #3
For heavens sake man...you could at least crop those p a l l e t s out of the picture...just move along folks...this is about a pit build nothing more...!
Pallets are there for good luck.
   / New BBQ pit in the making #6
You piqued my interest with this project. You call the project a BBQ pit and an accessory smoker. I've been cooking with every emaginable combo of barrels,pipe,sheet metal and masonary for years and would like to build something now. What range of tempatures will you run in the cook chamber? What tempature range for the smoking box?
   / New BBQ pit in the making #7
Pit? Trailer?
Bruce
   / New BBQ pit in the making #8
How much will it weigh?
   / New BBQ pit in the making #10
Just because the pallets are leaning towards a field does not mean they are supernatural. Or does it? :D
Looking forward to seeing pictures of some good BBQ ribs. !!!!
Probably as low as 150 and at the most 400 or so in the cook chamber.
Smoker be lucky to ever see 300 and most likely run 100 - 200.
The cook chamber will probably have to run 100 above what the smoker needs to be when using. Just a guess.
Just the cook chamber alone is a minimum of 935 lbs. By time I add fire box and vertical smoker on the ends with shelves and racks it will be over a ton. Im thinking at the lightest 2,200 lbs. This is only the firebox, cook chamber, vertical smoker with contents and no the trailer or anything else on it.
:thumbsup:
Again I probably wont really get going till late January or so. I have 800 feet of fence line to clear and install before any fun.
I will try to get some pictures of the trailer and maybe sketch out my ideas.
   / New BBQ pit in the making #17
Subscribed. I did notice the ladder looking like it was teaching the pallets the inverted V formation.
   / New BBQ pit in the making #18
Pit? Trailer?
Bruce
For sure on a trailer. To heavy of a pit not to be on a axle.
Must be regional differences. All the BBQ pits I knew were holes in the ground. Fill it with wood, burn to coals, then either (A) put in wrapped meat, cover with dirt, cook, or (B) put a grill over the pit and meat on grill. If it was all above ground it was just a BBQ.
All the photos I found were B&W. I must be old.
Bruce
View attachment 533384 View attachment 533385 View attachment 533386
Bruce
We do occasional cook in the ground, but now days there is a difference between, grilling, bbq, and smoking.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
JOHN DEERE 6430 PREMIUM TRACTOR (A60430)
JOHN DEERE 6430...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
iDrive TDS-2010H...
