New Barn
/ New Barn #1
Draagyn
Woodpecker, Canada
65 JD 3020, 75 IH 966
I am in the process of building a new barn. It will be 20x40 12 feet high with future lean too's off either side of 15 feet wide for total of 50x40 feet. The center for now will be half winter hay storage and half tractor and misc storage.
Here is my progress so far!
/ New Barn
/ New Barn #4
How did you come up with your spacing for your posts? They are farther apart then I'm comfortable with if I was building it. I'd go 12 feet max and be a lot happier with 8 feet. What are you going to use for purlins?
Eddie
/ New Barn #5
Nice!
I have a thought about your centered door placement though. Given the interior width of the center section of ~19 ft., centering the doors leaves ~4 ft. on each side. If you use a 12 ft wide door (10' is on the skinny side) and offset it to one side, you would have a more useful access and width of storage space along the opposite side, about 9 ft.--which is wide enough to store some tractor implements, 60" lawn mower, etc.
A 12 ft. wide door allows you to move some things in and out of the barn without moving a parked tractor or vehicle out of the way too. For example, if the parked vehicle uses 8 ft. of width when tucked in near the outside wall, that leaves a minimum of 4 ft. of clearance between the side of the vehicle and the door opening.
Just something to think about.
/ New Barn
Eddie
Ya I had initially designed for 10' spacing, but was advised by carpenter and structural engineer that stretching it out to save time with the footings would be ok.
4 ply 2x10 beam on bottom, 2x6 walls, and engineered trusses on top
/ New Barn
Nice!
I thought about putting the door off to one side right after we finished the footings.
I defiantly have to agree with you about a 12 foot door to the one side, would probably work better.
For now I think this will work for me, I plan on having one of the lean too's open for equipment storage.
And the centred door should look sharp!
/ New Barn #8
Well, if it has to be centered, then a 16' door would be your friend. :D
I have a 16' W by 9' H overhead door. It is easy to put up and down manually--no opener. I park my truck with an 8' wide bed and 6' wide tractor side by side in that door opening. If it matters now, or someday, you won't do that with a 10' or 12' door even though your building width would allow it.
I'm going to shut up now. :laughing:
/ New Barn
Having a garage door never occurred to me. Good idea but I'm sure it's not in my budget.
At the moment I have nothing that the door will interfere with and it's already done so I'm not changing it.
Thanks for the good ideas on future buildings
/ New Barn #11
Nice job! ..but I see you have your roof on already - what made you choose that tan brown color!:D
/ New Barn #13
It's hard to tell, but did you build a standard type wall with double bottom plates and double top plates over your big openings? Am I seeing that right?
Eddie
/ New Barn #14
If it were me, and I know it aint, I'd have put a continuous foundation under them walls. Did you have a structural look at that foundation?
/ New Barn
Yes Structural helped with whole design. Footings are 4' deep with 4 ply 2x10 beam across the top. Don't see anything wrong with that
/ New Barn #19
nice framing work.
Is that 3020 hard to start in the winter? My 4020 definitely is when the temps drop into the 20s, which is nothing up there.
/ New Barn #20
Good time for a Blue eh! I myself can't drink that stuff, instant headache lol.
Barn is looking great man, can't wait to see the finished product.
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65054)
2001...
2018 Chevrolet Suburban 4x4 SUV (A64557)
2018 Chevrolet...
PAIR OF SPAN-ON RIMS (A64278)
PAIR OF SPAN-ON...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2013 Ford Explorer 4x4 SUV (A64557)
2013 Ford Explorer...
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
