Need some help with a part
/ Need some help with a part #1
MESSMAKER
Bluegrass,KY
DK4710SE
I managed to lose the sleeve part of what I call the sway bars for the 3 point arm. It is the arm that controls horizontal movement of the lower 3 point arms. I called to order a new one and they can't seem to find it. Any idea what bobcat calls it so they can look it up? I tried stabilizer as well.:confused:
/ Need some help with a part #2
It's kind of late at night for me to dig out the manual to see if it might list them by name, but my initial thought was to call a local Kioti dealer to ask them for one for a CK series tractor. See if they can put their finger on the part for you......
/ Need some help with a part #3
Similar experiences lead me to believe that after you get one you'll probably find the missing one:D
/ Need some help with a part #4
I found them on the internet using "3 pt stabilizer. I have found then at different tractor stores which fit out tractors, but I don't know if you can purchase just the sleeve. I have seen them on eby for $70.00. Seem to be rather standard in size for cat. 1.
/ Need some help with a part #5
Bobcat does have an online Parts Catalog to find part numbers. You cannot order part direct but can look up part number before contacting a dealer. Go to Bobcat.com, choose Parts & Service tab, click on Genuine Bobcat Parts, the click the Parts Catalog link. Parts illustration for the sway bar/stabilizer is located in the Hydraulics section> 3pt Links System Group 1. Item #39 appears to be the outer (female) housing p/n 6695375.
I was going to post a direct link but it will not post.
/ Need some help with a part #6
Here is a picture reference of what SSdoxie provided above:
2020 John Deere 6120M (A62180)
2020 John Deere...
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
20ft trailer (A61569)
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
2005 Ford F-350 Crew Cab Pickup Truck (A61573)
2005 Ford F-350...
