sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,714
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I need a little leeway here regarding posts but I need an answer from a tractor guy that understands my situation. I need help ASAP.
I am building a doghouse for my neigbor that leaves his three beagles out over the winter. Nice guy but isn't around when the wind is blowing and can't see the old doghouse is insufficient.
The new house is 35" W X 60" L X 25" high (to eve) (gable roof) with a 30" W X 30" WX 20" high super-insulated "sleeping compartment" inside. The sleeping compartment has 1 1/2" foam on all four sides sandwiched between plywood. It's a box within a box thing. I'm a tractor guy not a builder. The dogs will have an open door to this compartment that is 8" X 10" and an offset outer main house door that is bigger, maybe 10" X 12" ? Should I vent the enclosed sleeping compartemnt since dead air/moisture could get trapped in it?
My concern is with the potential for condensation inside this sleeping compartment and what to do about it? I don't want to do more harm than good but have searched the web to no avail and need help. How do I avoid condensaton? Less insulation? Leave gaps?.
I wonder if vents at the gable will help but how will that small space/ventilation vent three dogs in a tight compartment? Remember this is a box-in-a-box thing with an indirect/separate door to the outside. There is a door to the sleeping area and a separate door to the outside.
Can someone help? The climate is mid-Ohio with a typical winter and flat ground with often windy conditons. Any help appreciated. Am trying to build ASAP.
