Need help identifying a Ford backhoe.
/ Need help identifying a Ford backhoe. #1
jptait
Ford tlb
I have a Ford back hoe, but I have no clue what model it is. I have uploaded a picture of the tag under the hood.
The tractor number is c689691
The model is cu411k
The unit number is 2f01b
Thanks in advance.
/ Need help identifying a Ford backhoe. #2
/ Need help identifying a Ford backhoe. #3
The standard backhoe for the 3400/3500 was the 10 foot model 730.poer
C = power class, eg. 3000, 3100, 3400, 3500., 340 etc
U = Utility
1 = Diesel
1 = 8 Speed
K = PTO, probably None
This is tractor only, the loadet would be a Model 340, Backhoe 730
Don't remember so much anymore, been a long time since I was involved.
Serial number ranges for year are approximate as they were pulled before production was scheduled so late one year and early following year could have some overlap.
I probably should have elaborated more I need to know what the model for the whole machine is. I ran the numbers on the hoe and it came back as a 765. I searched the unit number and found a thread that listed what I believe is a different model but had the same unit number. The unit number came back as a build year of 1982.
/ Need help identifying a Ford backhoe. #6
Model CU411K= 3400 diesel. no pto, 6X4 trans.
Built 2F01B = June 1, 1972, Day shift.
3400 built from '65 to '75.
Is your tractor blue or yellow?
/ Need help identifying a Ford backhoe. #7
Good stuff, thanks!!
Blue now but It might have been repainted.
/ Need help identifying a Ford backhoe. #9
How did you determine you have a 765 backhoe? Also what is the loader # ? it should be on a plate on the inside of the loader arms, where the support plate is welded.
I ran the numbers I found on the data plate on the hoe. It was on the left side of the machine near the main pivot. It's a pretty big stick. Seems a little too big for the machine. I'll have to get the loader number tomorrow. I attached the only picture that shows most of the machine that I currently have. I can take more tomorrow.
/ Need help identifying a Ford backhoe. #11
Don't know why but after looking at the picture, I'm thinking that the loader is from a later tractor due to the link type mount on the axle support. But the ID tag info makes it a 3400. Leads me to believe someone mounted a later loader/backhoe on you tractor.
The component number is 19-801. The plate for the loader is painted over.
/ Need help identifying a Ford backhoe. #13
Having a hard time finding out what the 19-801 fits. Been a long time since I worked for the dealer and I don't have access to the books any longer. I'll keep looking and see if I can find something for you.
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
2015 Freightliner (A64119)
2015 Freightliner...
(UNUSED) HARDEE 28 BLADE DISC HARROW (A64278)
(UNUSED) HARDEE 28...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A64556)
2019 Chevrolet...
2000 Ford E-350 Shuttle Bus (A64194)
2000 Ford E-350...
2018 Ford Escape SE SUV (A64557)
2018 Ford Escape...
