Need help identifying a Ford backhoe.
/ Need help identifying a Ford backhoe. #1
jptait
Ford tlb
I have a Ford back hoe, but I have no clue what model it is. I have uploaded a picture of the tag under the hood.
The tractor number is c689691
The model is cu411k
The unit number is 2f01b
Thanks in advance.
/ Need help identifying a Ford backhoe. #2
/ Need help identifying a Ford backhoe. #3
The standard backhoe for the 3400/3500 was the 10 foot model 730.poer
C = power class, eg. 3000, 3100, 3400, 3500., 340 etc
U = Utility
1 = Diesel
1 = 8 Speed
K = PTO, probably None
This is tractor only, the loadet would be a Model 340, Backhoe 730
Don't remember so much anymore, been a long time since I was involved.
Serial number ranges for year are approximate as they were pulled before production was scheduled so late one year and early following year could have some overlap.
I probably should have elaborated more I need to know what the model for the whole machine is. I ran the numbers on the hoe and it came back as a 765. I searched the unit number and found a thread that listed what I believe is a different model but had the same unit number. The unit number came back as a build year of 1982.
/ Need help identifying a Ford backhoe. #6
Model CU411K= 3400 diesel. no pto, 6X4 trans.
Built 2F01B = June 1, 1972, Day shift.
3400 built from '65 to '75.
Is your tractor blue or yellow?
/ Need help identifying a Ford backhoe. #7
Good stuff, thanks!!
Blue now but It might have been repainted.
/ Need help identifying a Ford backhoe. #9
How did you determine you have a 765 backhoe? Also what is the loader # ? it should be on a plate on the inside of the loader arms, where the support plate is welded.
I ran the numbers I found on the data plate on the hoe. It was on the left side of the machine near the main pivot. It's a pretty big stick. Seems a little too big for the machine. I'll have to get the loader number tomorrow. I attached the only picture that shows most of the machine that I currently have. I can take more tomorrow.
/ Need help identifying a Ford backhoe. #11
Don't know why but after looking at the picture, I'm thinking that the loader is from a later tractor due to the link type mount on the axle support. But the ID tag info makes it a 3400. Leads me to believe someone mounted a later loader/backhoe on you tractor.
The component number is 19-801. The plate for the loader is painted over.
/ Need help identifying a Ford backhoe. #13
Having a hard time finding out what the 19-801 fits. Been a long time since I worked for the dealer and I don't have access to the books any longer. I'll keep looking and see if I can find something for you.
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2022 EZ-GO ELITE...
John Deere Mini Excavator Wedge Lock Coupler (A65640)
John Deere Mini...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
Bush Hog 286 3-Pt Rotary Mower (A66408)
Bush Hog 286 3-Pt...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
