Need help finding electrical plug
/ Need help finding electrical plug #21
Too bad you aren't in Canada. Princess Auto carries these in 10 gauge. $6.00
Four pin trailer connectors might work also with a bit of finagling.
show_image_in_imgtag.php
But with those things you need to splice the wire...makes for a bad looking job.
/ Need help finding electrical plug #22
One more stupid question: I can get rolls of any wire I want, but what I'd really like is 2 10ga wires put together in a weatherproof plastic sleeve. I can make my own in split loom, but I really like the toughness of a pre-made 2 wire in a sealed sleeve.
Anyone know who sells wire already set up this way on line for reasonable cost?
McMaster Carr sells about anything you'd need. I can't link to the actual item, but here's the website: McMaster-Carr
10/2 Jacketed cable is item 7081K17. It's $1.63/ft.
/ Need help finding electrical plug #23
Yep! That is the downside of those. However, if you have a lathe, you can make splices with the exact inside diameter to match the bare wire and with the exact outside diameter to match the insulated part. A little solder, a little heat shrink and you have a butt splice that is much neater than the commercial ones. :)
/ Need help finding electrical plug #25
Builder, they apparently do ship to the US. From Princess Auto | Quality Selection Service & Value
"Shipping Rate - USA
The current shipping rates for packages to American addresses are $15.00 handling fee per order and $0.65/ pound. Air stage, oversize and freight shipments are subject to additional charges - our policy is to call with a price quote for these shipments before your order is completed. For business customers - please call our National Call Center if you have your own courier account and would like to charge your freight on your own account."
*Part# 8198137*
*Part# 8198137*
Thanks! :thumbsup:
/ Need help finding electrical plug #28
Are the actual pins on the #10 wired connectors any heavier than those on the ones with #14 wire? I've never had them stand up to more than a few amps, plus they seem to corrode pretty quick when exposed to the elements. They seem to be designed to make a connection that stays made, rather than unplugged on a regular basis and left open....
/ Need help finding electrical plug #29
Get fine strand tin coated copper wire and M/F weather proof connectors at a marine supply store like West Marine.
/ Need help finding electrical plug #30
/ Need help finding electrical plug #31
I'll do this also, but I use a plastic coated butt connector minus the plastic.
Most of the time I can just push the metal portion out, once in a while I have to cut it off.
But your right, it makes a much 'classier' looking connection.
/ Need help finding electrical plug #32
You might want to source out bare connectors rather than buying the insulated ones. It would probably be a bit cheaper and a whole lot handier! :)
/ Need help finding electrical plug #33
OK, I'll go with the Andersens and the corrosion proof safety boots on each side for a little extra corrosion protection. Now I gotta decide wire size. I think it's 10 ga.
If it's 12ga, do they make a lighter connector for 12 ga wire?
Sorry for a late response but did you get this done and what gauge wire did you use ?
What amperage draw are you applying to the circuit ?
ltr
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2014 Kia Sorento SUV (A61574)
2014 Kia Sorento...
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
