Need help finding electrical plug
/ Need help finding electrical plug #21
Too bad you aren't in Canada. Princess Auto carries these in 10 gauge. $6.00
Four pin trailer connectors might work also with a bit of finagling.
show_image_in_imgtag.php
But with those things you need to splice the wire...makes for a bad looking job.
/ Need help finding electrical plug #22
One more stupid question: I can get rolls of any wire I want, but what I'd really like is 2 10ga wires put together in a weatherproof plastic sleeve. I can make my own in split loom, but I really like the toughness of a pre-made 2 wire in a sealed sleeve.
Anyone know who sells wire already set up this way on line for reasonable cost?
McMaster Carr sells about anything you'd need. I can't link to the actual item, but here's the website: McMaster-Carr
10/2 Jacketed cable is item 7081K17. It's $1.63/ft.
/ Need help finding electrical plug #23
Yep! That is the downside of those. However, if you have a lathe, you can make splices with the exact inside diameter to match the bare wire and with the exact outside diameter to match the insulated part. A little solder, a little heat shrink and you have a butt splice that is much neater than the commercial ones. :)
/ Need help finding electrical plug #25
Builder, they apparently do ship to the US. From Princess Auto | Quality Selection Service & Value
"Shipping Rate - USA
The current shipping rates for packages to American addresses are $15.00 handling fee per order and $0.65/ pound. Air stage, oversize and freight shipments are subject to additional charges - our policy is to call with a price quote for these shipments before your order is completed. For business customers - please call our National Call Center if you have your own courier account and would like to charge your freight on your own account."
*Part# 8198137*
*Part# 8198137*
Thanks! :thumbsup:
/ Need help finding electrical plug #28
Are the actual pins on the #10 wired connectors any heavier than those on the ones with #14 wire? I've never had them stand up to more than a few amps, plus they seem to corrode pretty quick when exposed to the elements. They seem to be designed to make a connection that stays made, rather than unplugged on a regular basis and left open....
/ Need help finding electrical plug #29
Get fine strand tin coated copper wire and M/F weather proof connectors at a marine supply store like West Marine.
/ Need help finding electrical plug #30
/ Need help finding electrical plug #31
I'll do this also, but I use a plastic coated butt connector minus the plastic.
Most of the time I can just push the metal portion out, once in a while I have to cut it off.
But your right, it makes a much 'classier' looking connection.
/ Need help finding electrical plug #32
You might want to source out bare connectors rather than buying the insulated ones. It would probably be a bit cheaper and a whole lot handier! :)
/ Need help finding electrical plug #33
OK, I'll go with the Andersens and the corrosion proof safety boots on each side for a little extra corrosion protection. Now I gotta decide wire size. I think it's 10 ga.
If it's 12ga, do they make a lighter connector for 12 ga wire?
Sorry for a late response but did you get this done and what gauge wire did you use ?
What amperage draw are you applying to the circuit ?
ltr
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
Rake Master CR-72G (A64119)
Rake Master CR-72G...
159118 (A60430)
159118 (A60430)
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
DINGO TREE SPADE (A61572)
DINGO TREE SPADE...
