Need help finding electrical plug
/ Need help finding electrical plug #31
Yep! That is the downside of those. However, if you have a lathe, you can make splices with the exact inside diameter to match the bare wire and with the exact outside diameter to match the insulated part. A little solder, a little heat shrink and you have a butt splice that is much neater than the commercial ones. :)
I'll do this also, but I use a plastic coated butt connector minus the plastic.
Most of the time I can just push the metal portion out, once in a while I have to cut it off.
But your right, it makes a much 'classier' looking connection.
/ Need help finding electrical plug #32
You might want to source out bare connectors rather than buying the insulated ones. It would probably be a bit cheaper and a whole lot handier! :)
/ Need help finding electrical plug #33
OK, I'll go with the Andersens and the corrosion proof safety boots on each side for a little extra corrosion protection. Now I gotta decide wire size. I think it's 10 ga.
If it's 12ga, do they make a lighter connector for 12 ga wire?
Sorry for a late response but did you get this done and what gauge wire did you use ?
What amperage draw are you applying to the circuit ?
ltr
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
iDrive TDS-2010H...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2015 CHEVROLET SILVERADO (A60736)
2015 CHEVROLET...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
