Need Help ASAP starting tractor
/ Need Help ASAP starting tractor #1
lrunge
Independence, KY
Kubota BX22
Well, we got hit with anywhere from 8" to 24" of snow and Ice depending on where you live in the area. I got about 12" of snow crusted with ice. Unfortunately my son lost the key to my Kubota BX23 (Somewhere under the snow). The dealership is closed today. Nobody is getting around very well. Is there any way to start the BX23 without a key? It's cold so it will need the glow plugs to operate. I need to dig out my driveway.
Any help is appreciated.
/ Need Help ASAP starting tractor #2
I don't know about the specifics of the BX series tractors, but I know many tractors have very simple keys that are interchangable. My New Holland tractor key fits perfectly in the my Kubota and visa versa. Both are simple blades with one indent on either side. IF you key is similar, you could probably make a spare key out of some scrap plastic, wood or metal by just cutting it to rough shape and fiddling around with it. I know I've started some old tractors with the tip of a screwdriver by rattling it around a bit.
Thanks. I tried a bunch of different keys, Cub, Toro, DR but nothing would fit. I mistakenly said it was a BX23 but it is a BX22. It does not have all the safety engine kill switch when you are off the seat. I think I will try a series of small screwdrivers. It's supposed to go to -13 tomorrow night so I need to do what I can today.
/ Need Help ASAP starting tractor #4
Sounds like you'll have to get out the shovel. /forums/images/graemlins/smirk.gif
I did that this morning to get my daughter out to go to work. Even with 4WD it was a struggle. Plus the plows have built a wall across the drive. My back can't take to much of that.
/ Need Help ASAP starting tractor #6
whip out your sets of keys!
one of your keys is bound to turn the ignition...done it before in a pinch.
/ Need Help ASAP starting tractor #7
Do you have a neighbor or friend that has a Kubota? Try the key from them.
/ Need Help ASAP starting tractor #8
</font><font color="blue" class="small">( Sounds like you'll have to get out the shovel. /forums/images/graemlins/smirk.gif )</font>
I would hand the son the shovel.... Good lesson. /forums/images/graemlins/smile.gif
--->Paul
/ Need Help ASAP starting tractor #9
When I ws with out the keys for my Ford 2120, I just undid a few screws and dropped the panel that the lock was mounted in. One jumper to turn the fuel selonoid on and another to start it. Took all of 5 minutes. Good luck
Andy
/ Need Help ASAP starting tractor #10
Where is your spare?? /forums/images/graemlins/confused.gif. I have three keys to everything that needs one. G
/ Need Help ASAP starting tractor #11
Does anyone else here on TBN have a BX222 key? If so, can they post a picture of it here so that we all can see it and make some recomendations as to what other type of keys will work in his lock?
/ Need Help ASAP starting tractor #12
<font color="red"> Does anyone else here on TBN have a BX222 key? </font>
Maybe someone with a BX222 could just email a spare key to the original poster and he could use that one? /forums/images/graemlins/blush.gif
/ Need Help ASAP starting tractor #13
Have you contacted a local locksmith? Just a thought. They might have spares.
/ Need Help ASAP starting tractor #14
It's no help now, but I keep a key in the tractor tool box, one in my shop, and one in the house so I won't have to go too far to get one. Might be something to think about when it thaws.
/ Need Help ASAP starting tractor #15
Remove the ignition switch. Find the hot wire, ignition wire, glow plug wire and starter wire. Jump the hot wire and glow plug wire till hot. Disconnect the glow plug wire. Then jump the hot to the ignition and make a connection with the starter wire. Disconnect the starter wire once the tractor is running. have fun with all that snow. The temperature here today is 58 degrees. Tuesday it was -4 below zero.
Thanks for all that responded. My brother sent me a drawing of the key with specs and I was filing one down. Couldn't get it to work. And then my other son came over with a key he got from someone else and it worked. I've been out pushing snow with the FEL. Not the best way but it sure beats the shovel.
The son who lost the key doesn't live here or he would have been shoveling. Even if he is 30, I'm still his father.
Now when the dealership opens, I'll get some spares.
/ Need Help ASAP starting tractor #17
I went by the dealer I bought my JD from and asked for a 2nd key. He gave me one.
I replaced the ignition on my Gravely with another one because I only had one key to it. Now, I've a spare key to it, too. However, it would be no sweat to jumper it.
On your Kubota, you need to be able to jumper the line to the fuel solenoid, the line to the glow plugs and a line to the starter. The line to the fuel solenoid will have to stay energized after you've started it.
Good luck.
Ralph
/ Need Help ASAP starting tractor #18
You should have gotten 2 keys when you got the tractor. Where's the other one. Go look in the paperwork you got on the tractor and see if it's there
/ Need Help ASAP starting tractor #19
Mental note to self:
Find other key....
Stay out of Kentucky in the winter time. /forums/images/graemlins/blush.gif
You all are getting pounded. Good luck!
-Mike Z. /forums/images/graemlins/grin.gif
/ Need Help ASAP starting tractor #20
I also got a 2nd spare key with my kubota when I bought it. Did you double check your paperwork?
It might be in there.
ALso, call the dealer at home and explain your situation. He might tell you who has a tractor just like yours that you could call and get HIS spare key to try out.
Or maybe the dealer would be sympathetic and go down to the shop for you....
dwight
KUBOTA RTV 900 UTV (A62130)
KUBOTA RTV 900 UTV...
UNKNOWN TANK MANIFOLD (A60736)
UNKNOWN TANK...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2016 Ford F-150 Pickup Truck, VIN # 1FTMF1C85GKE26496 (A61165)
2016 Ford F-150...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61307)
2020 Takeuchi...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A61307)
Adams Load Out...
