Need Buying Advice!
/ Need Buying Advice! #11
That's what I had figured. They all look exactly the same--expect with different plastics.
That's why I'm tilting towards something bigger (even though my property doesn't necessarily warrant it). It's more of a "hobby" for me so I wouldn't mind having something nice or interesting to play around with.
Any thoughts on the old Husq. R155 front mount?
In any event, I appreciate the replies--especially given my posts isn't exactly in the spirit of this forum.
For 3k, I'd probably go the the cub cadet dealer and see about an XT2 or XT3 with a deck in the 50 inch range.
/ Need Buying Advice! #12
I think the Husky was more popular in Europe. They may still sell them there. I think the job of getting the best $3000 mower is pretty tough. Most have the lowest spec motors and non serviceable transmissions. They do pretty well on flat ground. I think you can expect 5-7 years before you start having problems.
/ Need Buying Advice! #13
I also mow 1/3 acre. Bought a John Deere 42" cut lawn tractor with V-Twin (21 or 22 hp?) Briggs and Stratton engine from Lowe's in 2007 for about $2000. Used it for 15 years and sold it for $800. Never had any problems with the engine or transmission. Had to replace some parts on the mower occasionally that got banged up. Just bought the same mower again (now $2300 at Lowe's). Can't go wrong for the price.
/ Need Buying Advice! #14
With your budget and if you’re handy with tools a smaller JD rider will last you a good long time. Proper maintenance on a new machine is the way to go.
/ Need Buying Advice! #15
I like the idea or the front mount mower. im getting pushed in that direction myself. As i golf a lot in me yard and the cut is important to me. The problem with the rider i have is the front tires mash the grass down before the cutting deck. i notice this while chipping around the 3 acres. That front mount deck get the the grass first before the tires get a chance to roll it down.
The ones i seen here in Ohio seem to be $ 1500 and up for anything that looked worth buying.
I wonder what the down side is to a front mount machine?
/ Need Buying Advice! #16
The mower decks on the JD riding mowers
are really crap! My brother-in-law took his
JD deck in to get welded and was told it would
take special welding to weld it JD used very
cheap metal to make the deck.
I have an MTD mower deck that I used for over
20 years and its still in good condition but the
JD deck only lasted a couple of years JUNK!!!
Tractor is OK
willy
/ Need Buying Advice! #17
I don’t know about JD’s riding mowers but the mid mount mower decks for their tractors are pretty solid. I frequent a JD forum and hear problems with mowing decks but it’s never about them being weak or poor metal. The problems are more about the setup.
/ Need Buying Advice! #18
I've been researching non-stop over the past week and my head is spinning! I don't know what is best for me. I hate to spend the money on a tractor and find out it's not a good fit for my property.
Should I just get a nice 42" standard rider?
Budget is $3k and under (with a heavy tilt toward under).
Where are you? Yes, too many choices... I'd probably just buy another rider, new. $1k for that used one is out of line. 42" deck is plenty big for 1/3 acre. Zero turns are nice, but you don't need one for that small lot. TSC, Lowe's, Farm & Fleet, Home Depot would all have want you need. Online w/delivery is an option, if you're not close to a store, but I would always recommend to shop local whenever you can...
/ Need Buying Advice! #19
Tractor is OK
willy
Willy, depends... if it is one from a big box store then yes, those are pretty cheap. My x394 is a solid machine with a heavy deck. Depends on what you buy.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
DSP 900 Balancer with Split Weight (A61307)
DSP 900 Balancer...
2011 Infiniti QX56 Multipurpose Vehicle (MPV), VIN # JN8AZ2NEXB9001685 (A61165)
2011 Infiniti QX56...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2013 Ford Focus Sedan (A59231)
2013 Ford Focus...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
