Need advice/opinions on which model to get
/ Need advice/opinions on which model to get #21
I'm just outside Charlotte. Got my BX24 to do some serious (I mean serious) landscaping work. No problems with ground clearance or otherwise. Loader lifts everything I need except a full cube of brick pavers. Hoe digs just fine. Pulls a garden plow with no problem. Mows like a champ. Don't let anyone tell you a BX with a MM won't mow a field that only gets it twice a year! I wouldn't want to tackle trees and rocks but tall grass is certainly no challenge.
/ Need advice/opinions on which model to get #22
I use the FEL to change out the MMM on my 7510. Piece of cake! Leave yourself plenty of floor space to roll her out.
I suppose w/o a FEL you could use a floor jack.
BD
/ Need advice/opinions on which model to get #23
Hi,
Don't know what shipping would be like but there is an 04 7610 loader\backhoe\loader tires that is in " perfect " condition here for an ask of
17K. Well known and well thought of dealer.
Here : Emerich Sales & Service, Inc. - Used KUBOTA Models
Good luck on your choices
Tom
/ Need advice/opinions on which model to get #24
When you're working in the dirt you will want a MMM off the tractor as it is the clearance limiting item when it's mounted. For all that is written about how easy the MMM goes on and off, there are equal entries about what a pain it is to take on and off.
My suggested decision points on the matter are pretty simple. The MMM benefits over RFM are in visibility and manueverability. If you can live with the RFM is these areas go RFM, save the money and laugh at the guy saying that MMM installation is so easy. Another RFM plus is that maintenance is a breeze as the zerks & transmission are always accessible where the MMM guys have to pull the mower. You can also use the tractor to lift the RFM to get the blades off for sharpening without removing the RFM.
This is all coming from somebody who owns an MMM and paid the extra dough for the mid-PTO option to power it. Given the same buying decision again it would be an RFM.
/ Need advice/opinions on which model to get #25
I bought my tractor about 1 year after my property and new I was going to buy 1. I also needed a lawn cutter immediately after I bought the place & that is how I wound up with my Cub cadet. In retrospect it turned out to be a great combination and if I was doing it again the only thing I would do different is to buy a bigger cub cadet 2000 series. My lawn tractor is also my snow blower.This is the reality, the cub cadet is cheaper than the MMM and I have a 50 inch deck and you can get the 54 as well. It is light and very maneuverable. The snow thrower was less than $1500 with soft cab, chains and ballast. It also leaves my Kubota set up for what I bought it for. A 2 wheel drive lawn tractor will always out cut a large tractor and do a nicer job. If I didn't live in snow country I would buy a zero turn mower for 3 grand or so. The convenience of owning the 2 over 1 that will do both for the same money or less for me is a very big plus. That is my perspective on the way I deal with the same situation
/ Need advice/opinions on which model to get #26
I've got the smallest of all, a BX1500 with the FEL.
I cannot believe what that thing will do, and has done.
I've got the 48" deck, because I have over 50 trees on my 1 1/4 acre lot.
Mows great, lots of power (for 48" anyway) and while the FEL is small, it does what I need it to do. I'm not suggesting that you go find a 1500, just that if you are using the tractor for mostly grass, don't sell those BX's short. They have a super tight turning radius as well, which is great for mowing around trees.
All cast iron, solid.
I just got back from test driving the 7610 HST. I am going with the 7610. Its fit me well and I felt comfortable with the size. Now I just have to decide on mower (mid or rear).
Whats RFM do you all recommend? I have a quote on the BEFCO and Woods. How is First Choice in comparison?
thanks again.
Jay
First guys...thanks for all your advice and thanks for answering all my questions.
Second....Christmas has come early. :D I have taken the plunge and now I am waiting on my B7610HST w/R4 tires,352 FEL and 60" mmm.
They had to order the 352 loader and mower. I was told I should get it the week after Thanksgiving at the latest. I know how you all feel now with the waiting game.
Yeah, I have been reading up on those. I guess most people are going with the Markham toothbar?
BTW...what other things should I get to help, like quick attach 3ph stuff, etc?
/ Need advice/opinions on which model to get #31
Well the tooth bar is very cheep and totally transforms your tractor it a very good digger, My regret was not getting the Tach-all and bucket. The tach-all is another 600 bucks but the bucket should be the same. But see now your up to what the B7800 would have cost LOL its a vicious circle. Get your tooh bar and you can make a Ballast tank or buy Kubotas
/ Need advice/opinions on which model to get #32
Jay,
Congrats on the 7610...you'll love it. Once you become "One" with your purchase you'll see how quickly it turns and how easy it is to trim with. As far as zerk access on the 60" MMM, I can get to all of mine. Also, can remove my blades w/o taking the deck off. Pick up the front with the FEL (block up the front tires).
The cut is better than I expected and even better with tuned up blades.
BD
/ Need advice/opinions on which model to get #33
Jay -
Congrats on the B7610 - you will not be disappointed!
In addition to a toothbar (the folks at Markham Welding are awesome!) - in terms of making 3PH attachments easier - I made V8Daves' "Telescoping Link" modification as described in this link:
http://www.tractorbynet.com/forums/...10-3pt-stabalizer-replacement.html#post555473
This makes swapping out 3PH attachments very easy. Should be standard in my opinion - but then again the B7610 is not a "Deluxe" model. ;)
You can check out some of my B7610 "At work" pics (link in signature) - so you can start dreaming about what other attachments to get! :D I'd love to get a BH - but that is one thing I can't even justify to myself ... :(
Enjoy your B7610!
Dan
Thanks Dan. I sent you a PM. I went to the thread that had the telescoping link exhange. However the manuals are not available to view to find the parts needed. Do you or anyone else have the part numbers?
I can see where this is a very useful mod.
Jay
/ Need advice/opinions on which model to get #35
Hi Jay -
I replied to your PM - here are the parts that I bought through TractorSmart.com - dunno if the prices are still the same - but you get a sense of the cost - I think I paid @ $130 total + @ 45 minutes to install.
Since TractorSmart deals in Kubota parts - I think you can also get these from your dealer. As far as an assembly drawing - your Kubota dealer should be on Kubotas Intranet / Parts catalog - ask them to print you out a picture of a B2910 3PH - as that's directly where the parts are coming from.
Hope that helps - let me know if any more Q's
Dan
PS If you plan on doing the maintenance on your B7610 youself - let me also recommend the "Work Shop Manual" - runs @ $75 - and you can also order from your dealer.
The broken links to manuals in the thread I referenced were to the "Parts Catalogs" - but I think you can also still request these from TractorSmart - not only for the B7610 - but also for any Kubota attachments (FEL, MMM etc). Also a "must have" IMO.
  • B7610 Telescoping 3PH Arm Parts.pdf
Dan,
Thanks so much for the part numbers. What a life saver. :) I'm surprised more people dont do this modification. It seems to be definitely worth the money.
thanks again,
Jay
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
43018CFL (A59228)
43018CFL (A59228)
UNUSED FUTURE LUXURY EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
(2) 3"X24" HYD CYLINDERS (A60430)
(2) 3"X24" HYD...
PALLET OF FABRICATED METAL PARTS (A60430)
PALLET OF...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61306)
2020 Takeuchi...
