Need advice on trailer purchase
/ Need advice on trailer purchase #21
Best choice in my opinion, would be an 18 foot, 10,000 lb. GW trailer.
Most of your statement, I agree with. Except this. A 10k trailer is generally built quite a bit heavier built than a 7k. He’s going to be pushing his tow limits, if the trailer is too overbuilt. It’s also going to add a lot of cost, for very little potential benefit IN THE OP’s SITUATION. I capitalized that part because, usually, I would
agree on this part, too.
/ Need advice on trailer purchase #22
If you Google 7K trailer, you will read lots of reasons to buy a 10K, from guys who have bought 7K.
Better springs, better wheel bearings (bigger) ,better brake drums (bigger), better tires (bigger), etc.
4 years ago, my 14K x 20' equipment trailer cost $4,400 OTD, and it weighs 3,300 lbs. It would likely be $800+ more today.
As an average I would assume a 1O,000 lb x 18' trailer would weigh somewhat under 2,800 lbs.
Kaufman trailers in North Carolina, is a major trailer builder. They would be a good source for weight/cost information.
I have seen Kaufman trailers on highways throughout the USA
They will deliver to you anywhere in the USA if need be.
I did not buy my trailer from them,.... but probably should have!
In my opinion, to save a few bucks on desired initial trailer expense, is almost always false economy!
/ Need advice on trailer purchase #24
The problem with short trailers and hauling tractors with attachments is you almost always have to put the tractor all the way forward to try to get everything to where it's not hanging off the trailer, in other words no wiggle room and it almost always puts to much load on the hitch verses with a longer trailer you can balance the load and it will pull much better, personally I would go with a 20' trailer with 2-7k axles with electric brakes on both axles. Good luck.
/ Need advice on trailer purchase #25
I'm building a house for my daughter about 30 minutes away and want to buy a trailer to haul my tractor/loader plus one attachment. Tractor and loader weigh about 3250 lbs. Since I cannot find anything used, I've decided to take the plunge and am considering a Big Tex car hauler (6000 lbs GVWR, model 60EC, 14' or 16'). This will handle a payload of about 4300 lbs, depending on length. This is more than ample weight for my tractor/loader/implement. The tractor/loader with an implement attached measures 14'.
On the surface, a 14' trailer seems a good fit for my needs. The ramps are slide in and not fold-down. My question is, what are some of the considerations I needs to take into account to be sure I don't make a mistake.
You should not get a "car hauler" built in the wheel track only style.
You want a smooth flat deck for a tractor, plus attachments
  • Good Post
Reactions: JWR
/ Need advice on trailer purchase #26
No one that I know has EVER wished for a smaller trailer..
Usually I’d agree but I have a 7k, 14k and a 20k trailer because the 20k is way to heavy for light work. Then I bought a 16k dump trailer to haul garbage. I might buy another one that’s lighter because a 4500 pound empty trailer is a drag on my lighter vehicles.
Well I can see this is a bit more complicated than I initially thought. All the feedback is very much appreciated and gives me a lot to take into consideration, many points I never even thought of. That's why I love reading these forums.
I will investigate an 18' 7K, since it should still within my budget and will give me an additional margin for size and weight. I honestly do not expect my towing needs to increase in the future and my primary concern is a comfortable tow that matches my truck and load.
What started out as simply a low-cost way to move my tractor 10 miles seems to have grown a bit.
/ Need advice on trailer purchase #28
From the back and forth of this discussion, it does seem as though the 18' 7K trailer may actually be the correct one for you.
I shopped!
You will likely get the best new equipment trailer pricing at Tim's RV Sales in Erving, MA. (go out MA. Rte 2).
Tim and his stepson, sell LOTS of equipment, car, and dump trailers.
Great people, worth the drive, but call first: 1-413-522-3410
No MA. tax, because you live in ME.
/ Need advice on trailer purchase #29
One other thing to consider if you live in Maine. Will you use in in winter. Salt will destroy the powder coat in 2 years. Look up Diamond-C trailers and see how they prep trailers for coatings. Buy one that is prepped like diamond-C. I bought an Alabama built trailer in 06 and most of the powder coat was blown off within 2 years.
/ Need advice on trailer purchase #30
I think " Lineman North Florida" hit it on the head... its not just about what will technically fit on the trailer and its rating, its how is the weight then distributed on the axles of the trailer and equally important on the hitch of vehicle towing it.
You can get something that technically works from a numbers (weight) calculation, but if its loaded with too much weight in the front, its a bad driving experience; if too much weight is in the back, its a dangerous driving experience.
The ability of the trailer is only one item in the calculation to the actual towing down the road event and how the experience goes for you.
/ Need advice on trailer purchase #31
Bottom line.... poor people buy short trailers that are just enough. Poor people probably shouldn't be buying trailers.
/ Need advice on trailer purchase #33
I have basically the same tractor fel and bb and have an 18 ft carhauler, I would not want anything shorter. With a rotary cutter on back it hangs over a couple feet. a couple hundred bucks now is nothing , you will regret going to short.
/ Need advice on trailer purchase #34
For a lot of people, the trailer is a one time investment. You will likely change vehicles before you change trailers. To me, it sounds like the 18’ 7k is the way to go. Get brakes on both axles, if at all possible.
Excellent advice. Buy more than you think you will need and plan on keeping it for long time. Don't cheap out on the axle ratings or brakes. Both are money well spent.
/ Need advice on trailer purchase #35
Yes,
This all day long. I am currently completely tearing apart a 2012 10K PJ dump trailer because it was powder coated and made from tubular stock. In fact I would avoid both of those things like the plague. That powder coat looks great until you realize that tiny little crack or chip is holding salt water directly against the metal for years with no way to get it out no matter how much power washing you do.
The tube stock also has no provisions to get the inside completely coated or cleaned out, so once that salt water goes in, it rusts the tube out from the inside and good luck trying to power wash inside the tube through the holes for the wiring... which let the salt spray in just fine.
When replacing these tube sections, I will and am gladly paying the weight and slight strength (in twisting force) penalty and going with C channel. This trailer was used for personal use, not that often during the winter, and was washed after winter outings (as you can see what a whole lot of good that did).... Powder coating... never again... not for the northeast.
Edit: To be clear my powder coat did not "blow off" in fact its still on there requiring a needle scaler to finish blowing it off with a nice thick layer of rusted steel still attached to the powder coat.
Eric
/ Need advice on trailer purchase #36
interesting topic. In a perfect world, I would also say look at 7K. The world of trailer possibilities seem to open up at 7K (2 3500 axles) and 16-20 length. BUT, in the real world, we all have to live within our limitations. I may have missed it, but what is the towing capacity of your Frontier? It is also true - if you buy a 14, you will wish you had a 16' and if you buy an 18'', there will be times you want a 20'. But, STAY within the capabilities of your tow vehicle. Filling the fuel tank may put you over the Gross Vehicle Weight. I have had many people tell me that it is not necessary to worry too much about weight limits - you will never be stopped by the Highway Patrol and you don't need to scale (not commercial). But, my trailer is a 14K Doolittle EZTilt and weights 3700. My tractor with loader and box blade weighs 6200. I sometimes stop at a CAT scale to see that the weight is correct. And my concern is NOT about being stopped for overweight. It is if there is an accident, no matter who is at fault, everyone including the HP and you insurance will be concerned about how heavy you were when it happened. That is why my first consideration is the tow vehicle. You also may want to concentrate on EZlube axles and other features such as tie down locations (stake pocket and rub rail) and off set front jack. Best wishes, Larry
/ Need advice on trailer purchase #37
I did the math, in a post. It’s earlier, in this thread. Moving to a 7k trailer is well within his limits and means he isn’t near maxing anything out. Feel free to check my math (I’ve been wrong, before).
/ Need advice on trailer purchase #38
The math is pretty easy.
Truck rated for 6800 lbs towing
Tractor weighs 3500. Lets call it 4k to be safe.
Means a 2000lb, 18', 7k rated car hauler will be easy to tow around and stay well within the limits for both trailer and truck.
Don't get a 6k trailer. Don't get a 14 or 16' trailer. Get an 18 or 20' 7k, and have less regrets later on!
/ Need advice on trailer purchase #39
Yes,
Eric
Powder coating is absolutely the worst finish for a trailer.
Manufactures use it because it is quick, and looks great...initially.
This pretty well sums up when seems to be the concensus so far. Looks like I'll be giving the dealer a call today!
Great feedback from everyone, much appreciated.
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
ATTENTION PLEASE READ (A64127)
ATTENTION PLEASE...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
