My solution for that excess strap
/ My solution for that excess strap #1
94BULLITT
Super Member
USA
yes
I found these "stretch locks" at Home Depot and thought they would be good for securing the excess strap. They come in 24" and 40" lenghts. They should work on a small strap on up to a big strap.
*at The Home Depot
They also work good for holding the strap together when it is not in use.
/ My solution for that excess strap #2
Hmmmmm... interesting. With my nautical background it looks like a re-purposed haliyard/sheet lock.
Of course a wee bit of bale twine could do the same thing. ;)
/ My solution for that excess strap #3
What do you tie up the excess on the stretch lock with :)
/ My solution for that excess strap #5
I have been using the giant twist ties you can get at Lowes or Home Depot.
/ My solution for that excess strap #7
I know most of us try to keep our chains cut close to length to the anchor down points of our trailers, However I have chains that I don't want to cut down, and have 5-6 ft extra, Instead of having it just lay there loose on the deck of the trailer, I pull the slack out with a cam-strap tie-down, hooking each end to the loose part of the chain and tightening the strap will pull the loose slack out along the side of the holding chain,;)
or can do as some of the truckers do, use the heavy duty bungee straps to hook the chain with, although the bungee's are known to break,
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
2012 Ford Expedition SUV (A64557)
2012 Ford...
2007 IC Corporation PB105 School Bus (A64194)
2007 IC...
