My NX6010
/ My NX6010
I see what you mean in your video on this blower. The auger would be better at pushing snow than the currently available blowers (I have a Land Pride). I wonder why they changed the design—maybe to cut cost?
McKee was making those augers before plasma cutters, water jets, or lasers where available. I think they used several large stamping machines which today would remain super expensive. Anyway, to avoid the machine time, and lower manufacturing cost, the augers tend to be made as a stripe of metal.
I read on a Deere forum of a guy who claims the McKee/John Deere/New Idea blowers are as good as everything available on the market. I don't know yet as our warm winter has truly been a very warm winter (off-setting last years super cold winter) and we've had rain, but little snow to try out the McKee and make a video of it working. What I did find video wise put a smile on my face:
/ My NX6010 #1,042
That McKee blower has to be well-built to handle an engine like that. We have had zero snow in Ohio this year (66F out now), so I have not had a chance to try mine either. You living up north, and out in the wild, probably need a McKee-style blower—good snow insurance anyway.
/ My NX6010
Nowhere near enough to consider blowing snow, but I plowed into my property to maintain access to my container and burn piles.
/ My NX6010 #1,045
Thanks for the ride good music. How is the Tractor seat doing for you?
/ My NX6010
Burning into the sunset.
I estimate that I've picked up 1/3rd of the windfalls on the new parcel.
I have two burn piles going right now with endless feeder piles getting shoved in. This is what 2:00AM Sunday morning looks like right now.
/ My NX6010 #1,047
Reading this whole thread? That'll be an odyssey!
Anyway, DDT414, I have not installed the new air seat. Instead of a Grammar 8o series air seat with 4" of travel, I have 4 new gas caps, two new rear fenders, two new cab tops, and boat load of extra metal guards, and whatever else that you and I can refer to as my "air seat fund." :eek:
I wish I had the air seat and I'm still wired for it.
My point looking at it from the south:
10432157_10203365284032344_1162811936567972312_n.j  pg
All along the shoreline I have dead logs.
10835369_10203356941143777_5001970207312183646_o.j  pg
That said, I made a video walking from the frozen beach on the point walking east to the road I made with the tractor.
Eric:
That seat is really nice. I wonder how hard it is to install? What about the seat safety switch? Will it plug into the existing outlet or will it need fancy rewireing?
/ My NX6010
Eric:
Installing that seat would be very easy.
Unrelated, I got around to showing more about how the Hiniker Big Ox plow articulates plowing an extremely uneven surface.
/ My NX6010
Eric:
Installing that seat would be very easy. All aftermarket seats assume a 11.25" W x 11"D mounting hole on a flat surface. The NX cab floor would require fabrication of a "shim" to create the flat floor.
/ My NX6010 #1,050
Thanks for the info. Making a shim sounds pretty simple. I'll study this some more and read some reviews.
/ My NX6010 #1,051
/ My NX6010
I looked through my photos trying to show just the seat plate and I found that I never took a good photo of that. But from what I saw, it looks as though the shim isn't necessary. I never measured the factory seat holes, but to my eye, from the bits of seat pan photos I did see, it looks to me as though an aftermarket seat will straight up bolt in.
Because of the step design of the seat pan, you want around 4" suspension travel seat model.
/ My NX6010 #1,053
I took a good look at the Kioti seat; the change should be simple. I'll contact the manufacturer regarding the seat safety switch. Thanks again for your help.
/ My NX6010 #1,054
Are you sure you even have a seat switch? Is that new for our tractors. I ask cause my DK does not have one.
/ My NX6010
The seat switch is a momentary style in the stock seat which is what everything I've seen uses.
/ My NX6010 #1,056
What did you find out about your trans jumping out of gear?
/ My NX6010
Since I was asked to make a video of the shifter popping out of range into neutral, I've logged about 45 hours of time on my tractor and it has not popped out of gear.
/ My NX6010 #1,058
Funny how things do that :) If I could just get my smoking issue fixed that way.
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2023 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2023 CATERPILLAR...
MOWER MAX SLOPE MOWER (A63276)
MOWER MAX SLOPE...
VERMEER BC1000 XL BRUSH CHIPPER (A67147)
VERMEER BC1000 XL...
2022 EZ-GO ELITE...
