My NX6010
/ My NX6010 #721
I just bought a new smartphone, and I vaccilated between the Motorola Droid turbo and the Apple IPhone 6. I went with the "droid". I didn't have any problem making it talk to my Chevy:). I am not really trying to say anything here, it was a hard decision for me. The droid was a few bucks less. But the biggest factor was that I already spoke " droid" and could make the phone play immediately.
And the op doesn't have trouble making his iPhone 6 talk to anything else as he stated in an earlier post so again I think the issue is with the JVC radio.
/ My NX6010 #722
And the remaining question would be, is it a bad radio (ie: won't pair with anything) or a general JVC to iPhone issue? That is the question that would be solved by trying to pair the radio with another device.
Aaron Z
/ My NX6010 #723
And the remaining question would be, is it a bad radio (ie: won't pair with anything) or a general JVC to iPhone issue? That is the question that would be solved by trying to pair the radio with another device. Aaron Z
+1 What I've been trying to get across. Troubleshooting is your friend.
/ My NX6010 #724
On a more serious note, I did have a new Kenwood radio that I couldn't get to communicate properly with my Android. I ended up calling Kenwood and got it going by resetting the head unit.
Travis
/ My NX6010 #725
Nothing like what the big boy tractors and combines use in the way of computers and GPS. Not sure those things even require human operators these days.
I have a farmer friend who was complaining because he has to turn the tractor himself at the end of the row instead of having the computer do it for him.
/ My NX6010 #726
Farmers are always complaining, not enough rain, too much rain. Etc
/ My NX6010 #729
That's why I reiterated it. How much time would it take to verify if the radio is the problem and needs to be returned (vs a general iPhone to JVC issue)
Aaron Z
It would be an easy thing to check.
/ My NX6010
The grapple works just fine with the expanded metal inserts. And on logs too, Island.
11084115_10204243807474881_3755218431074794032_o.j  pg
The Frontier BB4284H commercial box blade works great, fitting right on my SpeeCo CAT2 Quick Hitch.
10985433_10204257915747579_7557086197193366340_n.j  pg
/ My NX6010
I did some more clearing for where a pavilion will go in.
11148352_10204257024765305_8002457198421241703_o.j  pg
I also cleared 30 feet of wind falls along my shoreline with 2920 more feet to go. This is going to be a hobby.
11154704_10204257031245467_7397126543582214011_o.j  pg
Finally got around to looking at the beach quality at the end of the day on Saturday.
/ My NX6010
Ann also got some seat time. From her experience with her work tractors, she thought she needed to set the throttle up to operate.
/ My NX6010 #733
Eric, the Frontier BB looks good. How do you adjust working depth for the scarifiers? Each separately with a pin? Looks like the beam may have just two positions, either fully up or fully down, or can it be set in between, hydraulically?
/ My NX6010
The teeth have a manual provision for adjusting them up or down as you observed. In my short use so far I have not found any reason to manually set their height as my top link tilts the entire box fore and aft, thereby changing the scarifier depth relative to the ground. The most I've used the scarifiers is to hook one of them on a stump and try to lift the entire blade while driving either forward or backward in order to pop out root balls (which has worked on everything but oak tree taproots, and is a use that I consider a normal for a heavy-duty or commercial-grade box blade).
Also, the scarifiers themselves look as though they were plasma cut out of 80 or 100 series stock rather than forged.
/ My NX6010
After I knocked the snow off the box I found at my door this afternoon I realized that I received the Version I, Mark II, tilt cylinder from MIE! That was quick. A quick measurement of the lower clevis confirmed the 1" clearance I need to fit my NX6010.
MIE must be reading this thread because I forgot to call them and ask about stand-offs for mounting the anti-creep valve but two stand-offs were included in a bag. Thanks, MIE. Once everything warms up enough to touch, I'll chase it out to the tinkerage and see if I have all the bits I need to fiddle the check valve and banjos onto the new cylinder, fit the hoses and slide on a protective sleeve to keep it all neat and tidy.
/ My NX6010 #736
I am looking forward to seeing this.
/ My NX6010 #737
Who wants their Facebook time interrupted every time they get to the end of the row? :D
/ My NX6010
Did you know the thread pitch of the AMA kit is BSP 3/8-19?
I didn't until I realized that SAE-8 standoffs wouldn't work.
So I made a video where I reveal how to do it. Oh, and I meant to say of the first adaptor that JIC has the same thread pitch and size as SAE sizes up to SAE-16.
Here are the parts I got from my local Parker jobber.
PS: anybody need a stack of SAE-8 standoffs?
/ My NX6010 #739
BSP = British Standard Pipe, just like NPT is National Pipe Thread (tapered) :) Not sure where you got "perpetual" from. If the threads are straight and they use sealing, I think it's called a BSPP thread.
What are the standard fittings on the Kioti loader/etc? My Kubota was a weird mix, I added an oil gauge and that was BSP... but the bucket pins were 1" and the hydraulic fittings were all NPT.
I'm curious to see if the JIC fitting + an o-ring will work. ORB fittings IIRC have a specific recessed area to make the o-ring seal happen, hopefully it will seal just as good without that.
/ My NX6010
Adding an o-ring to a JIC fitting is done all the time. The o-ring simply needs a chamfer to sit in, which in this case is exactly what an SAE-8 o-ring does.
I'm calling british standard parallel pipe (BSPP), british standard pipe perpetual (BSPP), my own hodgepodge of BSPP and NPTP.
I think it is pretty obvious what I meant. Be happy I spent the time and effort to cobble the bits together and freely share how to do it, so others can do it at a lower cost. Kioti uses NPT, JIC, German Metric, and BSPP.
2020 CATERPILLAR 259D3 SKID STEER (A65056)
2020 CATERPILLAR...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2009 Generac SD060 75kVA Standby Diesel Generator (A66734)
2009 Generac SD060...
2022 WESTERNSTAR 4700 CONCRETE MIXER (A67714)
2022 WESTERNSTAR...
2025 XKH39 39in Hydraulic 4-Way Clamshell Bucket Mini Skid Steer Attachment (A66734)
2025 XKH39 39in...
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
