My breaker panel
/ My breaker panel #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
I just bought what I thought was a 24 space 100 amp main panel.When I mounted it I happened to look at the spots for the breakers and there is only room for 20,not 24.Upon further examination I see that the metal enclosure is marked correctly on the inside for 24 breaker and so is the outer metal cover with 24 knockouts.The box had been opened and taped back up.It seems someone switched the inside "circuit board' for a 20 spot one.I am fine with 20 spots as it's in a garage but will the panel pass inspection like this?.I'll have to leave the 4 bottom breaker knockouts in the front cover as I can't put breakers behind them.Ok to pass inspection like this?.Thanks.
/ My breaker panel #2
Why take the chance, take it back and get what you paid for.
/ My breaker panel #3
I would just take the 'guts' back and and get them to swap it out..
Shouldn't be a problem if you have the receipt and box...i've had to do it several times.
/ My breaker panel
This was the last one they had in stock and now I know why.It's mounted and I'll use it if it will pass like this.
Kennyd, I would but all they have left or smaller panels right now.
/ My breaker panel #5
Call the inspector and tell him your situation...see if you properly mark the panel "20 circuits" if he will let it fly.
If not, I would make the place you bought it from find you the guts, even if they had to special order it at their expense.
Good luck.
/ My breaker panel #6
I can't imagine anyone caring about that. The only issue I could see was if someone poked out the spots and there was a direct shot at the bus bars. Keep the knock outs in and you should be fine.
That from me along with $.50 will get you a cup of coffee. (Small) haha
/ My breaker panel #7
....and they make replacement knockout covers for use when a breaker is removed later. MikeD74T
/ My breaker panel #8
I don't think there's any problem here. If you read the sticker afixed to the inside of the panel it will explain the "problem" your having. You see, in most panels the bottom few spaces are approved for "tandem" breakers. By using tandem breakers you can get two circuts into one "space." I'll bet your bottom two spaces on each phase are aproved for tadem breakers, hence you have room for 20 breakers, but 24 circuts.
/ My breaker panel #11
Who decides if you can put in a tandem breaker? The mfgr or the electrical inspector? I have never noticed a sticker in a box mentioning tandems being allowed or not. I always thought you could add them anywhere in the stack. Please explain the logic of why they have to be in certain places.
/ My breaker panel #12
tandams? like "half size" breakers... or a single breaker with 2 110v circuts...
i thought it was simply a design issue. some support them, other dont.
/ My breaker panel #13
The width of a normal breaker for that brand (about1"), but is has two circuits and two trip levers that are not connected. You are still pulling from only one leg of power. Each half of the tandem will give you 120v. You cannot combine them to get 240v like you can with a full size 240v breaker that is 2" wide. That kind pulls from both legs, thus the 240v.
/ My breaker panel #14
The GE panels have the pins at the bottom of the bus bar that allows you to plug in th 1/2 inch GE breakers. The panels are usually labeled 20circuit/30max....30circuit/40 max exc. Homeline doesn't, but you can buy the 1" sqare-d tandem breakers for it.
If your bus has 20 1'" spaces, and your cover has 24 ko's and the enclosure is labeled 24 circuits, then chances are, as Bones said, someone swapped the guts out and took it back.
I doubt the inspector will even notice, as long as the panel cover fits snug, and there are no open ko's in the panel. Even if he did I really wouldn't think he would say anything unless he feels that down the road it might lead someone to believe that there are the extra spaces in the panel.
/ My breaker panel #15
Actually, on my GE, the tandem "offsets" and you do get 220v on the tied breaker that is only taking one place (although you loose 1/2 a place on the first one.)
My Electrician thought they would only pull 110 when we first went to install them, so I returned them and got normal 2" tied breakers saying they would only pull off one leg.
Then when I went to add more, I thought as I was down in the "tandem" range of my box, I would go ahead and use tandems and save some space, only to realize that you have to offset them, and by offsetting, you are picking up both legs, therby having 220V.
To the OP, look at the bottom of your box, and see if the buss bar looks different at the bottom 1/4 or so of your box then the top.
I think this is one of those things that all the manufacturerers do just slightly different. I cannot picture an electrical inspector failing an installation installed IAW a big name manufacturers instructions.
/ My breaker panel #16
bones1,
If you bought a panel labeled as 24 circuit, that's what it should be, not a 20 circuit. The HOM20M100C does not allow tandems to be installed. 20 full size breakers max. The HOM24M100C is 24 full size.
But to answer your first question, it probably would pass inspection here in my area.
Probably the best thing.
UL has standards that limit the number of breakers allowed.
There are actually two types of tandem breakers. CTL listed and non-CTL listed. The CTL stands for "Circuit limiting", meaning there is a rejection tab on the breaker that limits the placement to specific spots of the breaker IF they are allowed. The non-CTL listed tandems have a label affixed saying they are to be used for replacements of existing breakers only. They do not have the rejection tab.
/ My breaker panel #17
Gordon - On a square D panel there will be a sticker on the inside of it that will give you a head-spinning amount of information. torque spec's, wire capacities, bonding screw placment, tandem breaker information including placement, and more.
I only use square D panels so re: other brands all bets are off. The last square D panel I put in was a homeline 200amp that allowed tandems on the bottom few spaces only.
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
Kubota SVL 97-2 Skidsteer (A65579)
Kubota SVL 97-2...
2017 Ford F-150 4x4 Pickup Truck (A64556)
2017 Ford F-150...
Westendorf 8' Loader Bucket (A66408)
Westendorf 8'...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
New/Unused Wolverine 48in Mini Combination Bucket (A65583)
New/Unused...
