MX8 on a 4720
/ MX8 on a 4720 #1
leebritt
brentwood, tn
none
Will a 4720 with Cab and loader handle an MX 8 in some moderate hills? Mostly pretty level but some hills to mow at times. Thanks!
Lee
/ MX8 on a 4720 #2
I wouldn't do it. The power is there, but the mx8 is too heavy for it IMO. I think it is a CAT 2 implement.
Don't get me wrong, I think you could do it if you were careful, but I think an MX6 is the right size for the 4720
/ MX8 on a 4720
That's what I was thinking. I've got an Mx6 but had a chance at a good price in an 8 so thought I'd check. What about an MX7? No need to upgrade from a 6?
/ MX8 on a 4720 #4
I would consider the MX8, since it is two feet shorter front to back than the MX6. Deere does rate the 4x20 series to be compatible with the MX8. How old is your MX6 and which gear box do you have? If it has the gear box from Spain I would trade in a heartbeat.
/ MX8 on a 4720
How can you tell what gear box it has? It's about 7-8 years old. I got it used.
/ MX8 on a 4720 #6
I have heard that the reliable way to tell if they are the good ones, is that it will be a castle nut holding the stump jumper on. I think the China made ones are the good ones (oddly enough). I bought mine new in 2011 I believe and it has the castle nut. They have a 5 year warranty on the gearbox.
Steve has a good point about the MX8 being a dual spindle, and therefore shorter than the MX6.
/ MX8 on a 4720 #7
The one I had was a 2005 model with the problem gearbox (shaft really) it has made in Spain cast on the top edge of the gearbox. Some models were made in Mexico, don't know how good these are. The newest ones with a new design are made in China and have the 5 year warranty, supposed to be much better.
/ MX8 on a 4720 #8
Lee
I have a 4320 with FEL and 6 ft Frontier rotary cutter. Like you, I mow on some hills and I can't imagine going up much of a hill/grade with an MX8 rotary cutter due to the weight on the rear. With my much lighter weight cutter, the front wheels will just barely steer the rig going up a hill and that is with FEL and loaded front R4 tires. These comments are for 3pt hitch attach.
/ MX8 on a 4720 #9
I would go MX8 before MX7. I would rather have two 4' cutters paired for 8' than one 7' cutter behind that tractor.
/ MX8 on a 4720 #10
You did not say which version you are considering; 3pt, semi mounted, or pull.
/ MX8 on a 4720
This one is made in Canada but I can't find any reference on the gear box. I assume this one that has a gear box from Spain. Is that correct?
May want to dump it while it still works well and get the MX 8. Any thoughts?
A buddy uses his mx8 on his 4720 with the bucket and says it does ok. I guess I could always add some front weights or put something in the bucket.
Lee
/ MX8 on a 4720 #13
I would go for it if you can get a good price. If it works for your friend, it should work for you.
Look at the stump jumper on your MX6. If it's held on by a castle nut, it's one of the good ones.
/ MX8 on a 4720 #14
The double gearbox cutters have much SLOWER blade speed than MX6 or MX7.
If your cutter or mower dont have 17+k blade tip speed, you don't get a smooth finish.
2023 KOMATSU D61PXI-24 CRAWLER DOZER (A65056)
2023 KOMATSU...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
GAS CYLINDER TRANSPORT BED (A67714)
GAS CYLINDER...
1999 Freightliner FL112 Tri-Axle Dump Truck (A66736)
1999 Freightliner...
