3-Point Hitch MT5 Top and Tilt for 3pt hitch
   / MT5 Top and Tilt for 3pt hitch #1
Powellcrazy Gearman
Farmall H
I got a hydraulic top link for the 3pt hitch and now I am having a difficult time finding a good solution for the side link for tilting the 3pt
Wondering if anyone has already solved this?
I have been to tractor supply, and searched agristore.com
Photo of current hydraulic top link set up.
Thanks for any help.
   / MT5 Top and Tilt for 3pt hitch #2
For a side link look on A and I ag parts. Only place I could find one.
Thank you
Will check them out
I ended up going with agristore.com and modifying the cylinder to our set up
   / MT5 Top and Tilt for 3pt hitch #5
So they had something that matches? :unsure:
For the OP, your current hyd top link is a bit on the small side for the capabilities of your tractor.
The hitch has lift capabilities in excess of 6600lbs, you should really have a 3" dia cylinder IMO.
Good luck with what you have. ;)
   / MT5 Top and Tilt for 3pt hitch #6
I used the Fit Rite Hydraulics. I figured for cylinder size and to have the factory style slotted end it was a easy pick. Pin on and go.
FitRite is an awesome way to go for sure, I don’t want to wait or spend that much.
The route I went works for light duty implements we use.
Thanks for posting all your options for others to see and also something for me to upgrade too if need be.
   / MT5 Top and Tilt for 3pt hitch #8
Yeah the wait was the only down side. I ordered last fall so I got my kit in the spring. One thing I liked was no check valve but flow restrictors. I like to use them in float sometimes.
RING 2 STARTS HERE @ 9:15 AM (A60430)
RING 2 STARTS HERE...
CAT D8 (A58214)
CAT D8 (A58214)
2860 (A56857)
2860 (A56857)
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
PENDING SELLER CONFIRMATIONS (A59904)
PENDING SELLER...
2004 Komatsu HM400-1 (A60462)
2004 Komatsu...
