3-Point Hitch MT5 Top and Tilt for 3pt hitch
   / MT5 Top and Tilt for 3pt hitch #1
Powellcrazy Gearman
Farmall H
I got a hydraulic top link for the 3pt hitch and now I am having a difficult time finding a good solution for the side link for tilting the 3pt
Wondering if anyone has already solved this?
I have been to tractor supply, and searched agristore.com
Photo of current hydraulic top link set up.
Thanks for any help.
   / MT5 Top and Tilt for 3pt hitch #2
For a side link look on A and I ag parts. Only place I could find one.
Thank you
Will check them out
I ended up going with agristore.com and modifying the cylinder to our set up
   / MT5 Top and Tilt for 3pt hitch #5
So they had something that matches? :unsure:
For the OP, your current hyd top link is a bit on the small side for the capabilities of your tractor.
The hitch has lift capabilities in excess of 6600lbs, you should really have a 3" dia cylinder IMO.
Good luck with what you have. ;)
   / MT5 Top and Tilt for 3pt hitch #6
I used the Fit Rite Hydraulics. I figured for cylinder size and to have the factory style slotted end it was a easy pick. Pin on and go.
FitRite is an awesome way to go for sure, I don’t want to wait or spend that much.
The route I went works for light duty implements we use.
Thanks for posting all your options for others to see and also something for me to upgrade too if need be.
   / MT5 Top and Tilt for 3pt hitch #8
Yeah the wait was the only down side. I ordered last fall so I got my kit in the spring. One thing I liked was no check valve but flow restrictors. I like to use them in float sometimes.
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
2022 Horizon Trailer (A55973)
2022 Horizon...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
