3-Point Hitch MT5 Top and Tilt for 3pt hitch
   / MT5 Top and Tilt for 3pt hitch #1
Powellcrazy Gearman
Farmall H
I got a hydraulic top link for the 3pt hitch and now I am having a difficult time finding a good solution for the side link for tilting the 3pt
Wondering if anyone has already solved this?
I have been to tractor supply, and searched agristore.com
Photo of current hydraulic top link set up.
Thanks for any help.
   / MT5 Top and Tilt for 3pt hitch #2
For a side link look on A and I ag parts. Only place I could find one.
Thank you
Will check them out
I ended up going with agristore.com and modifying the cylinder to our set up
   / MT5 Top and Tilt for 3pt hitch #5
So they had something that matches? :unsure:
For the OP, your current hyd top link is a bit on the small side for the capabilities of your tractor.
The hitch has lift capabilities in excess of 6600lbs, you should really have a 3" dia cylinder IMO.
Good luck with what you have. ;)
   / MT5 Top and Tilt for 3pt hitch #6
I used the Fit Rite Hydraulics. I figured for cylinder size and to have the factory style slotted end it was a easy pick. Pin on and go.
FitRite is an awesome way to go for sure, I don’t want to wait or spend that much.
The route I went works for light duty implements we use.
Thanks for posting all your options for others to see and also something for me to upgrade too if need be.
   / MT5 Top and Tilt for 3pt hitch #8
Yeah the wait was the only down side. I ordered last fall so I got my kit in the spring. One thing I liked was no check valve but flow restrictors. I like to use them in float sometimes.
2019 Ford F-550 (A55973)
2019 Ford F-550...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
Deere 310L (A53317)
Deere 310L (A53317)
HUSQVARNA RIDING...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
