MT372D Mitsubishi Tractor
   / MT372D Mitsubishi Tractor #1
Skelley
Penna
Mitsubishi MT372D
I would like to ask about a starting problem I have with the tractor. I put the tractor away around October with it running fine. I go to try to start it in March and it will not start. I went over the fuel system with new filter and to see if the injectors are putting out. Everything checked ok. I checked compression and it looked good. I pulled the starter and check current and rpm's and it checked out OK. The only thing I am not sure about is the timing. Can the timing just Jump a tooth that would throw the timing out while trying to start it. Any suggestions would be great.
   / MT372D Mitsubishi Tractor #2
Does the engine not turn over or does it spin and not start?
This is the two cyl. right?
   / MT372D Mitsubishi Tractor #3
Don't take this the wrong way but can we assume that you did bleed the air after going over the fuel system? Have you checked the glow plugs?
   / MT372D Mitsubishi Tractor #4
It wouldn't jump timing.
   / MT372D Mitsubishi Tractor #5
You probably just have air in the system.
UNUSED FUTURE PC71-71" HYD PLATE COMPACTOR (A60432)
UNUSED FUTURE...
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
UNUSED 1RGC40 HIGH END MINI GOLF CART (A60432)
UNUSED 1RGC40 HIGH...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2023 RTVXG-850 SideKick (A61306)
2023 RTVXG-850...
