Mowing beside the road
/ Mowing beside the road #21
Roy, there is the option of an external PTO driven hyd pump and tank for those tractors with weak flows.
Still curious about the cost... I bet its scary, lol.
EDIT: heres an old ad, for a 2011 one, yup its expensive:eek: http://goo.gl/8Rjin
2011 MCCONNEL SWINGTRIM M1021008 BZ$21,094 PA, US
Stk #: X21008; Rear Mounted Boom Mower; (Price entered as 10,240 USD);
Warner Tractor and Equipment
Phone: (888)302-3897
Details
Send A Message
Add To Watch List
Share On
Updated: 12/03/2013 03:45:00 PM
MIE has a pto driven pump. They are around $3, 000.
Sent from my GT-P3113 using TractorByNet
/ Mowing beside the road #22
Has anyone actually priced the swingtrim or the Bush hog Power Trim? I've been considering this for some time for waterfront trimming.
To solve this problem, I bought a Hardee boom mower (model LR 50160). This is a 60 cutter head attached to a boom on a 3 point hitch PTO driven attachment ($17,400). It has its own hydraulics system driven by the PTO. The attachment is controlled by a joy stick that is permanently installed inside the tractor cab.
The weight of the attachment with its hydraulic fluid and counter weight was too much for my John Deere so I bought a used New Holland TL100 (2003 model with 2100 hours; not a TL100A). It is a 95 horse tractor that is much heavier than the John Deere. I paid $30,000 for the tractor.
This combination purchased in July 2013 has worked very well for my needs. The cutter head is tough and cuts small trees (3 to 4 inch diameter) well. Because of the adjustments that have to constantly be made to the cutter head position to account for the changing terrain, I drive very slowly while using the boom mower. You have probably noticed that county employees using boom mowers beside county roads are also traveling very slowly.
Bottom line, I am happy with this solution.
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
Caterpillar 302.7D (A64126)
Caterpillar 302.7D...
2005 Butler pole trailer (A62679)
2005 Butler pole...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
