Mowing beside the road
   / Mowing beside the road #21
Roy, there is the option of an external PTO driven hyd pump and tank for those tractors with weak flows.
Still curious about the cost... I bet its scary, lol.
EDIT: heres an old ad, for a 2011 one, yup its expensive:eek: http://goo.gl/8Rjin
2011 MCCONNEL SWINGTRIM M1021008 BZ$21,094 PA, US
Stk #: X21008; Rear Mounted Boom Mower; (Price entered as 10,240 USD);
Warner Tractor and Equipment
Phone: (888)302-3897
Details
Send A Message
Add To Watch List
Share On
Updated: 12/03/2013 03:45:00 PM
MIE has a pto driven pump. They are around $3, 000.
Sent from my GT-P3113 using TractorByNet
   / Mowing beside the road #22
Has anyone actually priced the swingtrim or the Bush hog Power Trim? I've been considering this for some time for waterfront trimming.
To solve this problem, I bought a Hardee boom mower (model LR 50160). This is a 60 cutter head attached to a boom on a 3 point hitch PTO driven attachment ($17,400). It has its own hydraulics system driven by the PTO. The attachment is controlled by a joy stick that is permanently installed inside the tractor cab.
The weight of the attachment with its hydraulic fluid and counter weight was too much for my John Deere so I bought a used New Holland TL100 (2003 model with 2100 hours; not a TL100A). It is a 95 horse tractor that is much heavier than the John Deere. I paid $30,000 for the tractor.
This combination purchased in July 2013 has worked very well for my needs. The cutter head is tough and cuts small trees (3 to 4 inch diameter) well. Because of the adjustments that have to constantly be made to the cutter head position to account for the changing terrain, I drive very slowly while using the boom mower. You have probably noticed that county employees using boom mowers beside county roads are also traveling very slowly.
Bottom line, I am happy with this solution.
   / Mowing beside the road #24
Sounds like a nice setup.
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
LOT: (1) Steel Plate Sheet, 1/4" Thick, 48" x 96", (1) Steel Plate Sheet, 1/4" Thick, 41" x 96" (A59076)
LOT: (1) Steel...
2014 Transcraft Trailer (A55973)
2014 Transcraft...
SAND ALL SANDBLAST POT & RESPIRATOR (A52708)
SAND ALL SANDBLAST...
2007 Chrysler Aspen SUV (A56859)
2007 Chrysler...
