Mower deck noise
/ Mower deck noise #1
Rubicon1000
Indianapolis
Kubota l2800 4x4 , l3301, bx2670-1, m4900
Hey guys, I've had my bx 2670 for two years and when I first got it the deck wouldn't raise enough to lock it. I read here and ended up adjusting the lift rod on the rear left. Anyway weather the deck is locked up or set for mowing anytime I hit bumps the deck makes kind of a banging noise.
Almost like it's bouncing around but it's worse with the loader on. Is it normal or does anyone else have the same thing? Thanks, Dan
/ Mower deck noise #2
When mines locked in the Top spot, it will bang going over bumps. Sometimes it will help if I try lower the 3pt a little after lifting it up all the way and locking it.
However, mine does not bang when it's in a lower mowing position. Sounds like something's wrong there.
/ Mower deck noise #3
Mine bangs in the top spot too (BX25D) 60 mower. I lower it a tad and it stops.
/ Mower deck noise #4
My BX2200 with the 60" MMM does the same thing raised to the top. Well it did until I solved it. I went to the local hardware store, got a large rubber stopper from the fastener isle, and got some rubber cement and glued it onto where my deck was banging. Solved my deck banging issue for less than 2 bucks.
/ Mower deck noise
Well I finally got the time to check it out, the deck wasn't raising quite enough to hit the stops. Now when it's locked in the up position no more banging. I like the idea about the rubber, if it comes back I'll probably go that route. Thanks, Dan
/ Mower deck noise #6
Does the BX23s have the same MMM as the BX2670...??? My BX23s mower bangs over bumps, and my place is nothing but bumps everywhere. I looked things over, i dont see any type of locking system to lock my deck. I might put some rubber bumpstops in there kind of like Diesel85 did, unless somebody can tell me how to lock the deck in the upper locking range. (???)
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
(2) UWS TRUCKBED TOOLBOXES (A62131)
(2) UWS TRUCKBED...
2019 Ford F-350 Service Truck, VIN # 1FD8W3HTXKEG31082 (A61165)
2019 Ford F-350...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2015 MACK CXU613 T/A 6X4 MID ROOF TRUCK TRACTOR (A59910)
2015 MACK CXU613...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
