mower clutch
/ mower clutch #1
sandfly
yanmar 146
any one know if the mower clutch for a 146 is adjustable. seems to cut off when it gets warm..or what replacements ???
need help yard needs to be mowed !!
/ mower clutch #3
the clutch coil is probably going open circuit when it warms up. this is common. could also be a faulty switch.
/ mower clutch #4
another thing to consider is..... Is the battery staying charged? this type of Clutch/PTO pull quite a bit of power from the battery, if the battery is weakened or not charging enough to keep up with the power being drawn from it, can cause the clutch to kick off, give the battery a good charge then run the mower, if the clutch stay engaged and doesn't kick off, then I would next check into the charging system, or possibly a new Battery,
/ mower clutch #5
that is another i should have suggested as mine had a blown up reg and when the battery went down it did release the clutch. i made my own reg for it and no problems with that part since, just need a new shaft and bearing carrier now....:mad:
PAIR OF PIPE RACKS (A68842)
PAIR OF PIPE RACKS...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
SCAN TO RECEIVE TEXT UPDATES (A65056)
SCAN TO RECEIVE...
Has compression. Unknown operating condition. (A64553)
Has compression...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
