mower clutch
/ mower clutch #1
sandfly
yanmar 146
any one know if the mower clutch for a 146 is adjustable. seems to cut off when it gets warm..or what replacements ???
need help yard needs to be mowed !!
/ mower clutch #3
the clutch coil is probably going open circuit when it warms up. this is common. could also be a faulty switch.
/ mower clutch #4
another thing to consider is..... Is the battery staying charged? this type of Clutch/PTO pull quite a bit of power from the battery, if the battery is weakened or not charging enough to keep up with the power being drawn from it, can cause the clutch to kick off, give the battery a good charge then run the mower, if the clutch stay engaged and doesn't kick off, then I would next check into the charging system, or possibly a new Battery,
/ mower clutch #5
that is another i should have suggested as mine had a blown up reg and when the battery went down it did release the clutch. i made my own reg for it and no problems with that part since, just need a new shaft and bearing carrier now....:mad:
2013 CATERPILLAR 299D SKID STEER (A65053)
2013 CATERPILLAR...
2025 Mounting Plate Skid Steer Attachment (A64553)
2025 Mounting...
5ft 3in Wagon Wheel Table (A65583)
5ft 3in Wagon...
2011 Kenworth T300 S/A 18ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
2015 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2015 Peterbilt 320...
2020 John Deere 470G Hydraulic Excavator (A64553)
2020 John Deere...
