mower clutch
/ mower clutch #1
sandfly
yanmar 146
any one know if the mower clutch for a 146 is adjustable. seems to cut off when it gets warm..or what replacements ???
need help yard needs to be mowed !!
/ mower clutch #3
the clutch coil is probably going open circuit when it warms up. this is common. could also be a faulty switch.
/ mower clutch #4
another thing to consider is..... Is the battery staying charged? this type of Clutch/PTO pull quite a bit of power from the battery, if the battery is weakened or not charging enough to keep up with the power being drawn from it, can cause the clutch to kick off, give the battery a good charge then run the mower, if the clutch stay engaged and doesn't kick off, then I would next check into the charging system, or possibly a new Battery,
/ mower clutch #5
that is another i should have suggested as mine had a blown up reg and when the battery went down it did release the clutch. i made my own reg for it and no problems with that part since, just need a new shaft and bearing carrier now....:mad:
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
2006 Mercury 115ELPTO 115hp Outboard Boat Motor. (A66738)
2006 Mercury...
2025 44in Single Cylinder Grapple Rock Bucket Skid Steer Attachment (A66734)
2025 44in Single...
2023 Tesla Model 3 Sedan (A66738)
2023 Tesla Model 3...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A69167)
2001 FREIGHTLINER...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
