Moving brush
/ Moving brush #11
I bolted a couple pieces of 6 foot long square tubing to the outside of my bucket and use them to scoop up brush piles and move them. The long "forks" allow me to carry a good size pile of brush, but I would not use them as a substitute for real forks when lifting pallets. Give it a try. It's cheap and you won't have much invested if it doesn't work for you.
See ya.
/ Moving brush #12
As others have stated, I've used my clamp on pallet forks on the loader bucket to load long pieces, and then pile smaller pieces on top. You do tend to lose some. Also I load with just the toothbar, being able to pick up quite a bit, and then by hand, put smaller stuff on top. While doing that, I usually grab as much as I can with my landscape/rock rake and drag that with me as I carry the rest in the loader. Other times I've laid out a rope and tied it around the pile and then to the drawbar. I just do whatever comes to mind at the time and what seems to fit the occasion. Best of luck, John
/ Moving brush #13
FIRST OF ALL THIS IS THE BEST WEB SITE I'VE EVER BIN ON...THATS BCUZ OF ALL OF THE GREAT GUYS HERE SO THANKS ..SECONKLY THIS IS MY FIRST REPLY EVER!!!! /forums/images/graemlins/grin.gif
IT'S LATE 2:10 AM AND I'VE BIN ON HERE SINCE ROUND 6PM.. AND WAS JIST GITTIN READY TO HEAD 2 BED SO I WASN'TGOIN TO REPLY TONITE BUT WHEN I SAW WHERE U HAIL FROM I HAD 2!!!!!!!!! /forums/images/graemlins/grin.gif be kinda neat if u live somewhere near augusta jim!! the name is todd by the way..
I'VE BIN CUTTIN N DRAGGIN BRUSH FOR YEARS HERE IN THE GOOD OL STATE OF MAINE.. IVE GOT A 10' X 5' TRAILER THAT I PUT 4' SIDES ALL THE WAY ROUND ON...I TAKE A 30'PJIECE OF TREE ROPE AND TIE IT INTO A LOOP AND SPREAD THE LOOP OUT EVENLY ON THE BOTTOM OF THE TRAILER...THEN I LAY 4 4' PIECES OF 2" OR SO BRUSH ON TOP OF THE ROPE SIDE TO SIDE...LAYER THE BRUSH ON TOP OF THE CROSS PIECES TILL THE TRAILER IS HEAPING..JUMP UP ON TOP AND WITH A LARGE SAW START CUTTING A FOOT AT A TIMEFROM ONE END TO THE OTHER..FILL AGAIN..
AND AGAIN..AND AGAIN...I'VE FIT ALL THE BRUSH FROM A 70' WHITE PINE IN 2 LOADS..WHEN THE BRUSH GITS 2 ITS DESTINATION ...PORTLAND AREA..THE LANDFILL I ALWAYS LOOK FOR SUMFN HHEAVY..I HAVE A PIECE OF 3/4 NYLON THATS BOUT 150'LONG AND IVE EVEN WRAPPED ROUND A PILE OF SHINGLES...GIT YER ROPE TIGHT AND DRIVE AWAY..OUT COMES A 10 X4X5' BALE OF BRUSH...IVE HAD THE TRAILER SO HEAVY THAT JIS B4 THE BALE COMES OUT OTHE TRAILER..IT LITERALLY LIFTED THE BACK END OF MY OL TOYOTA BOKUT A FOOT AND A AHLF OF THE GROUND /forums/images/graemlins/wink.gif
I ALWAYS PULL IN 4 LOW AND START IN 3RD GEAR THO..LOL
THANK GOD MY FRONT TIRES WERE CRANKIIN!!!
ONE TIME THE DUMP ATTENDANT {A GRUMPY OLD GUY}...CAME RUNNIN OVER
AND SAID ICOULDNT LEAVE THAT THERE!!!I SAID WHAT YA WANT ME 2F DO ...HE SAID IT HAD F2B 75' OVA THERE!!! YOULL JIST HAVE 2 MOVE IT ALL BY HAND AND STORMEED OFFF.... NECESSITY IS THE MOTHER OF INVENTION...HENCE...TRACTORS...ROPES ...BLOCKS /forums/images/graemlins/cool.gif...I WHIJPPED OUT A STEEL CHOJKER A 2 TON SHIEVE.MY 3/4 NYLON ROPE AND RERIGGED AND !!!!!! THERE U GO !!4 HOURS WORTH OF WORK IN 10 MIN FLAT....NOW I KNOW THAT MY LILL STORY DIDNT FIX ALL YER PROBLEMS BUT IF YOULL TAKE A STEP BACK THERE R VERY MANY TIMES MORE THAN ONE SOLUTION 2 ANY PROBLEM... I JIST GOT LAID OFFF /forums/images/graemlins/confused.gif...JJIST BOUGHT A USED ISEKI 38 HP 4X4 WALL CLIMBIN TRACTOR!!!!! /forums/images/graemlins/grin.gif AND LIVE IN MAINE /forums/images/graemlins/grin.gif MAYB WE COULD HOOK UP ...UNBELIEVABLE THAT D LAST STRING I WAS GONNA READ TONITE COULD VERY WELL B A ADAD GUM NABAAA!!!EMAIL ME AND HAVE A GREAT DAY 2 DAY...IT SURE JPOURED HERE 2NIGHT EEEEEHHHH /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif
/ Moving brush #14
I made a set of pallet forks that are fixed at 42" center to center on an angle iron that slips over the front lip of the bucket.
After several attemps to move my piles, the problem was that I lost to much brush until I got to the final destination.
I then made a set of 3 intermediate teeth that slip between the main forks. The additional teeth are .75" sch. 80 black iron pipe.
I use 3 bolts to attach to the main forks in about 5 minutes.
No more problems and at 36" long it holds a bunch of brush.
GrayBeard
/ Moving brush #15
You will find lots of good info on this site.
Read a lot & find the way you want to go.
If you don't have a tractor yet, when you get one, be sure to get a front end loader with a quick attach so you can aquire different implements & change them quickly to suit your job.
Sounds like you have a lot of work to do and having the right forks or brush grapple with the bucket removed will increase the amount of work you are able to accomplish.
25 yrs ago, I purchased a 59 ford dump truck for 500.00. Have since spent more than that on it, but was one of the best investments I ever made. Is not road worthy, just use it on the farm.
Attached is a set of forks I made to use.
/ Moving brush #16
This is a small clearing in the woods, I make a large pile. When it is raining & I expect it to rain all day, I light the pile & burn it.
One load on the forks.
/ Moving brush #17
This is a different set of forks I built with a grapple.
I built this set later (shorter so could unload in dump truck easier).
There are other brush grapples on tbn that appear to me would work even better.
/ Moving brush #18
Jim, I've sure unloaded lots of trailer loads of brush using two chains like you described.
/ Moving brush #19
JCA....
I actually did the same thing as JimR. I piled roots, brush and logs onto my 5'x10' utility, pulled it with my tractor to where I wanted to unload and then pulled the tow straps up and over the pile to unload. later I went back with my box blade and pushed everthing tighter to burn.
43018CFL (A59228)
43018CFL (A59228)
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
2020 CAT 308 (A53317)
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
