Moving brush
/ Moving brush #1
JCA
Maine
Kubota B7510
Hi folks. Wasn't sure whether to post this on Attachments or Projects.
What's the best way to hook up with a nice-sized bite of brush from a brush pile and haul it off to a dumping spot? Bucket with grapple? That would cost a lot of money (or time if I made it myself) and it would only take small bites. Bucket hooks and chains? Pallet forks and chains? Wrap a chain around it and drag it? What'do'ya think?
I've got a bunch of brush piles around my property I want to get rid of. It's hilly, so can't get a truck in there. Not so hilly, though, that I can't get a tractor to the brush piles, or at least near. I've been thinking I'd buy a chipper, but they're expensive, and I'm not sure that it's the best solution to my problem, with my tractor's limited HP (of the tractor I haven't yet bought, that is) and a manual feed (can't afford hydraulic). And with a wife and a little boy, I'm worried about safety. So I'm not just trying to figure out how to do this job; I'm trying to figure out what attachments and accessories to buy with my tractor.
I've got a good place to dump brush; I could also burn it once I get it out of the woods. The hard part is getting it to the dumping/burning spot: small sandpit (for burning) next to a cliff (for dumping). It's a quarter mile or so. I can get my pickup truck back there ONCE I get the brush out of the woods. So I could haul it all the way back with the tractor, or I could dump it in the back of the pick up truck and drive it back. Whatever works best.
So what works for you?
Thanks,
Jim
So that's the job I want to do: get the brush out of the woods, up the hill, and into the back of the pickup truck.
/ Moving brush #2
We selectively cleared 5 acres; took out all the trash (Brazilian Pepper trees and wild grape vines), leaving the native growth. There was a lot of trash. We ended up with 48 large piles of brush spaced throughout the property. Grape vines come up like a carpet and bring a lot of dirt with them; we weren't successful in burning. I thought about a chipper, but vines are tough to chip, especially when loaded with dirt.
So, since we were scheduled to get a large excavator to dig a pond, we decided to bury the trash growth in a remote corner of the property. All I had to do was move the piles.
Even with the large, rented Cat 416C with a root rake (picture attached), the only thing that worked was a rake full at a time. We tried pushing it. We tried pulling it. We tried piling it on a flat bed trailer; that worked, except it was harder to unload than moving it a little at a time.
I spent 6 days or so on the big tractor, snatching a rake full of brush, then traveling distances up to 700 feet to dump it. Load after load; until I finally had a "pile" about 10' high, 20' to 30' wide, and 200' long (picture in the next post).
Now, I have a better way -- I bought a 6' x 12' dump trailer which I can unhook, fill, then hook up again and pull with the tractor. But, it was too late for one of the dirtiest jobs I've ever done. Sorry I don't have any magic bullets or good news; the only good news is all the seat time you're going to get.
/ Moving brush #3
Jim, it sounds like you have an interesting challenge to test your ingenuity. But that's half the fun of tractoring, I have found. Since every situation is a bit different, what works for one person may not be your best solution. Here are a couple of things I have done just to get your wheels turning. Maybe others will have even better ideas.
I've had to move many tons of fallen trees and ones I have felled... mostly pine... out of the woods to a burn pile. However the distances are less than yours and it's mainly across a smooth open field, so we have generally been able to simply push the piles with the FEL.
Sometimes you have to get down a trail between trees, fences, etc., or across lawns, etc. where you can't just push a large pile where it needs to go.
If you have the money for it, you can get one of the smaller landscape trailers (say 12 ft or less) and you can get a receiver hitch for the tractor's 3pt so you can pull it off road with the tractor. You can pile a lot of brush on it with the loader, but you'll pretty much have to unload it by hand later. This solution gives you a versatile trailer you will use for many other things also.
A cheaper solution if you have some rough carpentry skill is to build what the old timers called a "stone boat" out of 2x8's with 4x4's as skids using rough cut or pressure treated lumber. I once made a 3 ft by 8 ft one that did great pulled behind the tractor or even the pickup. For hauling brush, you'd want one that is wider and maybe even had some sides. If you needed something for one-time or occasional use, this is a way to do it without spending a lot of money. Lots of skid marks though!
An alternative to this is to start with a "carry-all", which is a metal frame that attaches to your 3pt hitch. You supply some lumber to build a small platform on which you can strap down whatever you want to carry. The carry all frames are only $50 or $75 at places like Tractor Supply.
If you have some initial or one-time needs to move brush, these are some low cost or multiple use approaches so you don't have to spend big $$$ on serious specialized additions like hydraulic grapples, etc. Of course, if you are doing work commerically or are just an equipment junkie, by all means get the real deal!
/ Moving brush #4
Part of the resulting pile.
/ Moving brush #5
I also built a bucket-mounted root rake for my little TC18, and, while it wouldn't hold as much as the big Cat, we made almost as many trips with it.
/ Moving brush #6
A toothbar on the bucket makes it about 1000x easier to pick up brush.
I would want a 4 wheeled trailer to dump it in (preferably a dump trailer). 4 wheeled so you can unhook it from the tractor and then hook it back up after it's full.
Even if you had to unload it by hand it wouldn't be the end of life. It's easier to unload than to load.
/ Moving brush #7
Here is a neat trick for unloading a trailer full of brush without using your back. You can use chains or cable for this. Get two lengths about 2 1/2 times the length of your trailer bed. Also one more cable to go around your anchor and connect the two cables. Fasten one end of each cable at the rear of the trailer. Eye bolts work wonders for this. Lay the cables forward. Pile your brush on. Flip the cables over the pile. You will need some type of anchor to hook the anchor cable to where you are going to pull them off. Attach them to whatever you have in that area as an anchor and drive away. The cables or chain will unload the load for you. If you do not have an anchor. You could use the hitch on your pickup or whatever for an anchor.
/ Moving brush #8
I have moved tons of brush around my property with my lip mount bucket forks. They work the best with freshly cut limbs, as they tend to grab hold of each other so you don't drop many. But I have also picked up entire brush piles and moved them elsewhere.
After the brush pile has been there a while, gets real dry and leafless, and the limbs get brittle, its hard to get a good bite with the forks as they tend to break the limbs and some fall through. Still a great tool for this however.
/ Moving brush #9
</font><font color="blue" class="small">( Here is a neat trick for unloading a trailer full of brush without using your back.)</font>
That's a great tip. I'll have to try that when I finally make a decent sized trailer /forums/images/graemlins/grin.gif.
/ Moving brush #10
<font color="blue"> So what works for you? </font>
You could probably make any of the methods you listed work. The positive grip of a grapple or 4in1 bucket would be a great. I would nix the chipper, just because chipping is a long, tedious process with a sizeable brush pile.
There have been plenty of limbs, tree trunks and root balls to dispose of on our property. Bucket forks are maybe not the perfect choice, but are what I've used with reasonable success. A few limbs always want to fall off on the way to the dump, so there is some clean-up. And smaller stuff needs to be loaded by hand, either on the forks or thrown into the bucket. But forks can move material pretty fast because it takes little time to load/unload.
If you have a long way to go between piles and dump, use forks and a trailer. Tow the trailer with your tractor and load it with your forks. Then, off to the dump.
OkieG
/ Moving brush #11
I bolted a couple pieces of 6 foot long square tubing to the outside of my bucket and use them to scoop up brush piles and move them. The long "forks" allow me to carry a good size pile of brush, but I would not use them as a substitute for real forks when lifting pallets. Give it a try. It's cheap and you won't have much invested if it doesn't work for you.
See ya.
/ Moving brush #12
As others have stated, I've used my clamp on pallet forks on the loader bucket to load long pieces, and then pile smaller pieces on top. You do tend to lose some. Also I load with just the toothbar, being able to pick up quite a bit, and then by hand, put smaller stuff on top. While doing that, I usually grab as much as I can with my landscape/rock rake and drag that with me as I carry the rest in the loader. Other times I've laid out a rope and tied it around the pile and then to the drawbar. I just do whatever comes to mind at the time and what seems to fit the occasion. Best of luck, John
/ Moving brush #13
FIRST OF ALL THIS IS THE BEST WEB SITE I'VE EVER BIN ON...THATS BCUZ OF ALL OF THE GREAT GUYS HERE SO THANKS ..SECONKLY THIS IS MY FIRST REPLY EVER!!!! /forums/images/graemlins/grin.gif
IT'S LATE 2:10 AM AND I'VE BIN ON HERE SINCE ROUND 6PM.. AND WAS JIST GITTIN READY TO HEAD 2 BED SO I WASN'TGOIN TO REPLY TONITE BUT WHEN I SAW WHERE U HAIL FROM I HAD 2!!!!!!!!! /forums/images/graemlins/grin.gif be kinda neat if u live somewhere near augusta jim!! the name is todd by the way..
I'VE BIN CUTTIN N DRAGGIN BRUSH FOR YEARS HERE IN THE GOOD OL STATE OF MAINE.. IVE GOT A 10' X 5' TRAILER THAT I PUT 4' SIDES ALL THE WAY ROUND ON...I TAKE A 30'PJIECE OF TREE ROPE AND TIE IT INTO A LOOP AND SPREAD THE LOOP OUT EVENLY ON THE BOTTOM OF THE TRAILER...THEN I LAY 4 4' PIECES OF 2" OR SO BRUSH ON TOP OF THE ROPE SIDE TO SIDE...LAYER THE BRUSH ON TOP OF THE CROSS PIECES TILL THE TRAILER IS HEAPING..JUMP UP ON TOP AND WITH A LARGE SAW START CUTTING A FOOT AT A TIMEFROM ONE END TO THE OTHER..FILL AGAIN..
AND AGAIN..AND AGAIN...I'VE FIT ALL THE BRUSH FROM A 70' WHITE PINE IN 2 LOADS..WHEN THE BRUSH GITS 2 ITS DESTINATION ...PORTLAND AREA..THE LANDFILL I ALWAYS LOOK FOR SUMFN HHEAVY..I HAVE A PIECE OF 3/4 NYLON THATS BOUT 150'LONG AND IVE EVEN WRAPPED ROUND A PILE OF SHINGLES...GIT YER ROPE TIGHT AND DRIVE AWAY..OUT COMES A 10 X4X5' BALE OF BRUSH...IVE HAD THE TRAILER SO HEAVY THAT JIS B4 THE BALE COMES OUT OTHE TRAILER..IT LITERALLY LIFTED THE BACK END OF MY OL TOYOTA BOKUT A FOOT AND A AHLF OF THE GROUND /forums/images/graemlins/wink.gif
I ALWAYS PULL IN 4 LOW AND START IN 3RD GEAR THO..LOL
THANK GOD MY FRONT TIRES WERE CRANKIIN!!!
ONE TIME THE DUMP ATTENDANT {A GRUMPY OLD GUY}...CAME RUNNIN OVER
AND SAID ICOULDNT LEAVE THAT THERE!!!I SAID WHAT YA WANT ME 2F DO ...HE SAID IT HAD F2B 75' OVA THERE!!! YOULL JIST HAVE 2 MOVE IT ALL BY HAND AND STORMEED OFFF.... NECESSITY IS THE MOTHER OF INVENTION...HENCE...TRACTORS...ROPES ...BLOCKS /forums/images/graemlins/cool.gif...I WHIJPPED OUT A STEEL CHOJKER A 2 TON SHIEVE.MY 3/4 NYLON ROPE AND RERIGGED AND !!!!!! THERE U GO !!4 HOURS WORTH OF WORK IN 10 MIN FLAT....NOW I KNOW THAT MY LILL STORY DIDNT FIX ALL YER PROBLEMS BUT IF YOULL TAKE A STEP BACK THERE R VERY MANY TIMES MORE THAN ONE SOLUTION 2 ANY PROBLEM... I JIST GOT LAID OFFF /forums/images/graemlins/confused.gif...JJIST BOUGHT A USED ISEKI 38 HP 4X4 WALL CLIMBIN TRACTOR!!!!! /forums/images/graemlins/grin.gif AND LIVE IN MAINE /forums/images/graemlins/grin.gif MAYB WE COULD HOOK UP ...UNBELIEVABLE THAT D LAST STRING I WAS GONNA READ TONITE COULD VERY WELL B A ADAD GUM NABAAA!!!EMAIL ME AND HAVE A GREAT DAY 2 DAY...IT SURE JPOURED HERE 2NIGHT EEEEEHHHH /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif
/ Moving brush #14
I made a set of pallet forks that are fixed at 42" center to center on an angle iron that slips over the front lip of the bucket.
After several attemps to move my piles, the problem was that I lost to much brush until I got to the final destination.
I then made a set of 3 intermediate teeth that slip between the main forks. The additional teeth are .75" sch. 80 black iron pipe.
I use 3 bolts to attach to the main forks in about 5 minutes.
No more problems and at 36" long it holds a bunch of brush.
GrayBeard
/ Moving brush #15
You will find lots of good info on this site.
Read a lot & find the way you want to go.
If you don't have a tractor yet, when you get one, be sure to get a front end loader with a quick attach so you can aquire different implements & change them quickly to suit your job.
Sounds like you have a lot of work to do and having the right forks or brush grapple with the bucket removed will increase the amount of work you are able to accomplish.
25 yrs ago, I purchased a 59 ford dump truck for 500.00. Have since spent more than that on it, but was one of the best investments I ever made. Is not road worthy, just use it on the farm.
Attached is a set of forks I made to use.
/ Moving brush #16
This is a small clearing in the woods, I make a large pile. When it is raining & I expect it to rain all day, I light the pile & burn it.
One load on the forks.
/ Moving brush #17
This is a different set of forks I built with a grapple.
I built this set later (shorter so could unload in dump truck easier).
There are other brush grapples on tbn that appear to me would work even better.
/ Moving brush #18
Jim, I've sure unloaded lots of trailer loads of brush using two chains like you described.
/ Moving brush #19
JCA....
I actually did the same thing as JimR. I piled roots, brush and logs onto my 5'x10' utility, pulled it with my tractor to where I wanted to unload and then pulled the tow straps up and over the pile to unload. later I went back with my box blade and pushed everthing tighter to burn.
bad boy zero turn 72 (A56859)
bad boy zero turn...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
66'' SKID STEER BUCKET (A61567)
66'' SKID STEER...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
