Most comfy zero turn
   / Most comfy zero turn #1
Bungiex88
Dysart
73 Farmall 574, 2016 mahindra 1533
Looking to buy a zero turn mower this coming spring. My situation is I have arthritis in my lower back. I遏・ mowing about 10 acres. I was considering buying the Ferris 3200z 61 inch deck with the 37 Briggs. My question is is there a more comfratable zero turn mower out there then this. Im not worried about getting a cut that looks like a golf course or anything. Just have a ton of grass to mow and it痴 not the most groomed land. Just looking out for my back for the future. I see numerous zero turn mowers have there own version of suspension but who has the most comfratable. The reason I want a zero turn is trying to save time with mowing. I love mowing and dont mind spending all day doing it it痴 just really hard now since we started filling the house with kids.
   / Most comfy zero turn #2
I had a Country Clipper. It used a joystick at the end of the right arm rest for directional control so I felt I was able so sit in a more relaxed position with my back against the seat-back than on a mower with the two handles. The seat "suspension" was a couple of coil springs underneath and I replaced them with "lighter" coils to give a "softer" ride. Had to be careful - to soft a ride resulted in bottoming out on big bumps. I had 3 1/2 acres of ex-pasture land.
   / Most comfy zero turn #3
The Toro with My Ride system
   / Most comfy zero turn #4
I also have major lower back problems. Before the 2017 mowing season I bought a Hustler Super Z HD with 72" deck and air suspension seat to mow my rural property. The air suspension seat is a huge improvement over the mechanical coil spring suspension seat I had on a previous mower. Post mowing back pain has been significantly reduced. Don't know if the Ferris has an air suspension seat available, but if they do it might be the best of both worlds for comfort. Vic
   / Most comfy zero turn #5
Looking to buy a zero turn mower this coming spring. My situation is I have arthritis in my lower back. I�・ mowing about 10 acres. I was considering buying the Ferris 3200z 61 inch deck with the 37 Briggs. My question is is there a more comfratable zero turn mower out there then this. Im not worried about getting a cut that looks like a golf course or anything. Just have a ton of grass to mow and it痴 not the most groomed land. Just looking out for my back for the future. I see numerous zero turn mowers have there own version of suspension but who has the most comfratable. The reason I want a zero turn is trying to save time with mowing. I love mowing and dont mind spending all day doing it it痴 just really hard now since we started filling the house with kids.
I have a Bobcat ZTR. I had neck fusion about 7 years ago. The seat coils on the cat was wearing me out. I sunk money into their suspension seat, have not regretted it. Wouldn't mind having one on my Mahindra 1526.
   / Most comfy zero turn #6
Get the air suspension seat, most higher quality zero turns offer one, also get the heavy lawn roller out and start rolling it to smooth it out.
   / Most comfy zero turn #7
Unless your 10 acres is super smooth I'd suggest the biggest tire CUT you can get with a mid mount mower and a long travel air suspension seat.
Even with an air seat, ZTR's are a rough ride unless you regularly roll your lawn to make it perfect and you have no rocks, trees or tree roots.
If it were my 10 acres of lawn I'd be tilling 8 of those acres and getting a farmer to plant something useful and have that land generate a little income.
It use to be half hay fields and half pasture. I知 planting an orchid in half of it and the other half is by my pond I知 making it nice so I kicked the cows out from around the pond. And some of it will be used for meat chickens. If I wasn稚 doing anything with it I would of never mow r that hay off of just to have an open field of grass. All but a small part will be filled with apple, pear, peach, plum, cherry, and nut trees. And another section is going to be filled with hardy kiwi, red and black raspberries, and a lot of blueberry bushes. Another reason I want a zero turn since I値l have a lot of obstacles to mow around.
   / Most comfy zero turn #9
I'd imagine a Ferris with suspension and an air ride would be about the smoothest riding machine, or the Toro with a floating platform and air seat. Don't know if those combinations can be purchased from the dealer.
Will
   / Most comfy zero turn #10
I have a Hustler X-One with the same air Grammer seat. Love the ride. Couple that with the Ferris suspension and you should float over any rough ground.
296385 (A57192)
296385 (A57192)
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56438)
2017 Rogator...
Case 2390 Tractor (A59814)
Case 2390 Tractor...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
