robot
I don't recommend buying a Lester Bldg. at all, I bought one and just weeks ago had to pay an Amish Crew from Graber Bldgs. to come in and fix the mistakes and poor workmanship on it. I paid Lester Bldgs. extra to install dripstop on the house portion, but they shorted me on that, I also paid Lester extra to install 3/4" plywood on all exterior walls, but again they shorted me and they incorrectly engineered the exterior of my bldg. I dealt mainly with the Lester Regional Manager who provided me with one of their Lester Bldgs. Dealer/Builders from out of state saying he did "Good Work", which turned out to be a lie. It took this Lester Dealer less than ten days to build my building and then he left town, but before he did he told me that if he had to come back for any reason it would be a $500 minimum. Just weeks later we had our first rain, at which time I noticed that I had 25 leaks in my roof, I had puddles all over inside my bldg., well I wasn't going to pay this Lester Dealer to come back and fix his screw-ups so I got on the roof and fixed them myself and what I found was that this Lester Dealer had installed the roof screws missing the roof purlins and some screws were too short. It took me two days to fix this problem.
It took me two years to finish and move into my Lester Bldg. at which time we started noticing more serious problems, to the point that I finally called in an Amish Crew to check out my bldg., who found several problems, but before I paid them to fix my Lester Bldg. I first called out the Lester Bldgs. Regional Manager and asked for help. This Lester Manager was shocked at my bldg. problems, but after he spoke with Lester Bldgs. Upper Management he told me that Lester Bldgs. doesn't feel any responsibility for my "Building Issues" and will not be helping me. I then asked Lester Bldgs. if they could at least give me a discount on the soffit materials that I need to fix my bldg., which totaled around $2,500, and again they said no. So at that point I paid them Amish Crew to come in and fix my Lester Bldg. and the following is what they found: 8 Roof Purlins not nailed at all, they actually pulled one up and out to show me, which would explain why on windy nights it sounded like my roof was going to blow off. A lot of my soffit only had one staple holding it on and when the staples tried going thru the steel they bent only allowing 3/8" to go into the facia board, which would explain the rattling we were hearing. Lester also used vented soffit on the gable ends which should have been solid soffit. Gaps/Openings in the roof valleys where wind was blowing in and had blown my attic insulation away in that area, cold wind was also finding its way into my furnace plentum/duct work, I'm sure rain had to be coming in too. Facia boards barely on the trusses and nails missing the truss, we had to sister nailers on the sides of some trusses. Facia cover not cut to fit properly causing the ends to dip down an inch on the ends. 2 bird blocks not installed, but the ones that were installed were not nailed at all, I personally screwed every one of them off myself. This Lester Bldgs. Dealer/Builders name is C&C Construction, Willis Childress is the owner and he definitely did poor workmanship on my bldg., but Lester Bldgs. is who recommended him to me and Lester Bldgs. shorted me on roof dripstop and exterior 3/4" plywood and incorrectly engineered the exterior of my bldg., but Lester Bldgs. doesn't feel any responsibility for what they call my "Bldg. Issues", and for that reason I would not recommend anyone buying a Lester Building.
