Modified 2 wheeled tractors
/ Modified 2 wheeled tractors #1
Tor Arne
Norway
Same Explorer 65, MF 135, MF 30, MF165, Volvo BM 55, Volvo BM 425, Volvo BM 2254, Terengmester skidder, Ford 3000, Fordson major, Derreng unknown model, IH B275, MAN 4R2, Gutbord sub compact.
After the war there was a great demand for small tractors to replace a horse on small farms in Norway. Here are some versions that were popular on small farms where a conventional tractor was too big or too steep to be used.
Rapid with powered wheels on the trailer
Motor standard U9 with front wagon and one converted with belts to be used for logging
Agria Grombasen converted to articulated tractor with pto and 3 point hitch older and newer type.
Grombasen translates to cool boss
Agria converted to toolcarrier
Agria Drott converted With tracs to be used for logging
Last one is a Nibi G519 med powered wheels on the trailer
/ Modified 2 wheeled tractors #2
/ Modified 2 wheeled tractors #3
I came across the picture below while searching through old 35mm slides to show at my parents' 60th wedding anniversary. This was taken in Weisbaden, Germany around 1968 or so. I'm the cute little guy in the trailer along with my older brother. The older fella in the trailer was a German man we called "Uncle Ernst". The house we lived in (shown below) housed 3 families in the main section along with Ernst, his wife and his sister in a little add-on area on the left side of the house. The entire property was owned by a hotel and Ernst and the ladies worked the gardens and the orchards that supplied the hotel restaurant. You can see the apples on the trees as we head into the orchard to "help" Uncle Ernst.
I don't know what kind of tractor it is, but I'm sure it dated back to right after the war, if not before.
/ Modified 2 wheeled tractors #4
Tor
These "specials" are very interesting. Though times were tight, IT is interesting how the two wheeled tractors grew to four wheels under the influence of the owner's needs.
That front logging winch is a real beauty!
The Agria Grombasen looks very nicely done!
Thanks for sharing the photos. If you see any more, I'm always interested!
/ Modified 2 wheeled tractors #5
Agreed, very interesting to read about
/ Modified 2 wheeled tractors #6
Very cool stuff! Some of those are bigger than a compact tractor!
Is not quite sure which brand of two-wheeled tractor, but it has self-loading front wagon
Here is a home-made, created to bring elk home from the woods during hunting
/ Modified 2 wheeled tractors #11
Here in Slovakia, when I search for "malotraktor" in the classifieds (small tractor -- which encompasses both 2 and 4 wheel tractors), about half of the advertisements are homemade-- either making a two wheel Vari or Agzat (or other) walk behind into four wheels, or else completely homemade two or four wheel tractors using various combinations of automotive engines, automotive transmissions, and sometimes old tractor transmissions.
I looked at one last year, that was made by hooking a Czechoslovak diesel walk behind tractor (motorobot it was called-- much larger than the vari system) (or at least the engine from it) to an ancient transmission and rear wheels from a four wheel tractor. The guy had to pour a bit of oil into the cylinder to get enough compression to start it, and while it came with a spare, apparently better working motor, I decided I'd pass on it! :)
/ Modified 2 wheeled tractors #12
There is non written rule here. No pictures. It didn't happen.:laughing::laughing: By the way my mother was born in Sirk Zeleznik. I still have cousins in Holic. I understand but can't write Slovakian.
1996 International 4700 (A64127)
1996 International...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
213065 (A64276)
213065 (A64276)
5000bu GRAIN BIN (A64277)
5000bu GRAIN BIN...
Cattle Feeder (A65640)
2020 International LT625 48" Sleeper (A62613)
2020 International...
