Mini Modification
/ Mini Modification
Barryh said:
Mine are also 55 watt halogens. I'm sure they put a drain on the battery, but to me it's worth it. I go back into the woods at night every once in a while. It's nice to see everything bright and lit up.
55 Watts is a little less than 5 amps. The alternator is rated at 15. So two lights plus the fan (which is 5 amps and you don't have one) gives about 15 amps. If you use a trickle charger while parked it does not matter too much if you run the battery down a little while operating. I actually have a switch on each front lamp so I can run just one if that's all I need. I have a flashing light in the back, but I have not measured its current. I only use it when on or near the road.
The extra light is a big help and you probably only run them a few times a month, so no big deal.
/ Mini Modification #52
The 180 does have a cooling fan in the back, not on top of the unit. I only run the lights once in a while, there so bright I can see in back of me. I haven’t needed to add a backup light. I have a trickle charger, but haven't felt the need to use it.
When doing a lot of moving snow at night. I will be hooking up the charger. I didn't think to put in separate switches, good idea. I plan to do the cigarette lighter thing for other accessories. I’m sure I'll be using the trickle charger a little more after that.
I mounted a little tool box on the inside of my cab the other day. I put basic tools in it for out in the field. It also works as an extra place to set things when the lids closed.
2017 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2017 Ram 2500 4x4...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2013 Infiniti JX35 v SUV (A59231)
2013 Infiniti JX35...
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
2013 BMW X5 AWD SUV (A59231)
2013 BMW X5 AWD...
