FF13 mini excavator mods
   / FF13 mini excavator mods #11
If you still have the factory Torch spark plug it might be the problem. I have found them to be hit and miss when it comes to reliable operation. I replace with NGK (From Japan if you can get it).
ETA: For the B&S in my Typhon 1-ton the NGK plug is BP6ES
Thanks. I show BPR6ES which is probably the resistor plug. Didn't get a chance to work on it yet. Have to go shopping. Will try a new plug. Was going to double check the gas flow and see if the oil module shutoff is acting up. Otherwise I will pull the tank and carb. I need a new hose routed out where I can change the gas filter if it has one.
Put in the new plug. Oil was showing about 1/3 on the stick. Topped it off with a half quart of oil and it ran. Didn't try to dig today though.
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2014 International ProStar Truck, VIN # 3HSDHSJR1EN768255 (A54865)
2014 International...
2016 Ford F-450 12ft Flatbed Truck (A55852)
2016 Ford F-450...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
