Mini Excavator Questions
/ Mini Excavator Questions
That excavator rake looks like a good bet for debris and demolition. I couldn't find one for my B21 so made something similar. Together with a hydraulic thumb, it works much better than a standard bucket for clean up chores. I would not hesitate to buy the one in your link.
Hey that's a nice one! You should start selling those. :)
/ Mini Excavator Questions #62
I'm going to have a concrete pad poured and a cover made for storing the U55. What is the usual position of the boom/stick when an excavator is parked? How big should the pad be and how high does the cover have to be?
/ Mini Excavator Questions #65
Most machine live their lives outside. I place my cylinders so the minimum amount of chrome is exposed.
/ Mini Excavator Questions #66
If uncovered - the less the chrome shows the better. I park in my shed so I pull everything in to save room and having the chrome showing doesn't matter if out of the elements.
Yeah, it makes a lot of sense about protecting the chrome. I want to keep it under a roof so I guess that won't be as critical and won't have have the boom and stick extended way out to cover the chrome. A concrete pad would have to be really long with the arm extended all the way out. I'm thinking a 10" x 20'-24' pad and cover should be OK?
/ Mini Excavator Questions #68
That should be more than enough. I am on 8' x 20' and have room to spare.
/ Mini Excavator Questions #69
99% of all excavators or any construction machinery sit outside their entire life . I have never seen any damage to the rods .
How tall is your shed?
That's good to hear. But what about damaged wiring from mice? Anyone know of any low barrier to put around machinery to keep mice out?
/ Mini Excavator Questions #72
Mothballs and luck
/ Mini Excavator Questions #73
My door is 8 1/2' and the ceiling in the shed is about 11' sloping to 9'.
I use some of that mouse rodent replant stuff and just sprinkle it all over the gravel. We also have an outdoor cat so between he two I have not had any issue in that shed as the cat seems to like to hang out there. Sometimes sleeps on the Mini ex or the tractor. Works for both of use - she gets a roof and an elevated platform and I get NO mice!
I'm going to have a small 12'x22' pole barn with 12' high walls and 10' high door to house the mini ex that finally showed up today in the rain. It looks like I can do some serious digging with this thing. The ripper is still on back order. It was the first time I ever drove a excavator and it was interesting driving it down the ramps off the trailer. LOL
/ Mini Excavator Questions #75
Some operators could load that on a railway flatcar without a ramp. You can climb over obstacles by lifting the machine and resting it on the blade. Then swing the house around and lift the tacks off the ground. Lower the front blade to lift the front higher as needed. Then push until you get the tracks to bite
Practice picking up beer cans with the thumb.
When I was putting over 500 hours on my excavator I was impressing myself that I developed real skill levels, Now I put about 100 hours on the machine in two years, not doing anything requiring a lot of skill and I have lost my finesse with the machine. Master Yoda, I am no longer one with the force.
Just out of curiosity, does anyone make a soft Cab for the FOPS Mini's? I put a soft cab on my L39. I'll never want to plow snow again without protection.
Yeah, I've seen some Youtube videos of people loading them on trailers without using ramps. I don't know if I'll ever get to that skill level.
/ Mini Excavator Questions #77
Nice machine, welcome to the world of excavators. You'll forever be changed.
/ Mini Excavator Questions #78
That is one heck of a starter excavator! Nice.
Is it OK to hose the area around the track and rollers after each use to get all the dirt and debris out? There doesn't seem to be any spots to grease in that area that water will wash away.
/ Mini Excavator Questions #80
YES -best to always clean your sprocket and rollers. Less dirt/rocks/etc causes less wear. I think even Kubota recommends it in the book.
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
2015 MACK GRANITE (A65643)
2015 MACK GRANITE...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
NEW Predator Gas Water Pump (A62613)
NEW Predator Gas...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
