Miller Multimatic 200
/ Miller Multimatic 200 #11
Brown Road, the Multimatic 200 and Millermatic 200 are different machines. Pretty sure the MultiMatic is a new model in 2013. I bought my MultiMatic 200 for the portability. I weld in 3 locations so for me portability was important. Also wanted to have a stickwelder if I need to jam an electrode deep into rusty metal, or weld outside in the wind. I haven't used it as a stick but I will someday. Also bought the spoolgun for Aluminum but haven't even opened the package. And I also want to TIG someday, but I think The MM200 is a DC TIG, which is not great for Aluminum, but may be OK for steel. I don't know much about TIG. Then a few months later Everlast came out with the 140E for $400, pricewise, I could have bought a 140E for each location and carry just the gas bottle around? ,,,,,or something, and have more than few hundred$ left over. Well anyway I've got the MM200 and I do like it. The 230v capability provides some headroom for thicker material or larger weldments. I recently completed wiring 230v at my garage at home, so if a project needs 230v I have to bring it home. The Multimatic 200 doesn't give you a good way to tie up the cables (for portability). I'd say the main pluses are light weight/portability, 115/230v operation, and the option to stick-weld. If you are OK with the cost, then you are getting a special machine, and paying for it too. It sure welds sweet! In my case I haven't needed more power as most of the stuff I build is 3/8" and less. It's kind of a hard machine to "recommend" pretty much if a guy needs one he knows the price and already knows his 'needs'. I don't have anything to say about duty cycle, as I've never had a machine shut down, ever. I can't think of any welds longer than about 6 inches though, so maybe that's the reason. I don't weld for a living and have no reason to consider duty cycle. If it welds 6 inches, that's probably enough. My 120v Miller 135 never shutdown either. Are you having problems with the welder or the supply breaker?
Oops my fault I think. I accidentally wrote Millermatic instead of Multimatic.
/ Miller Multimatic 200 #12
After a little thought I am probably welding more than 6 inches.,,,,,,Thus the need for a bigger machine.
Sounds like you have bigger projects than I do. The reality check for me is that I have 230v capability and so seldom need it, that I KNOW where I'm at.
If I look back at all the stuff I've made, it's almost ALL rectangular tubing, and gussets, brackets, hinges etc. These are usually corner-to corner, all of 2 inches of welding, sometimes 3 or 4". Really, NEVER a 6" weld. And so very seldom at max power as most is 3/16" or less. Makes no sense for me to spend even a dollar gearing up for a 6" (and at max power) weld because it happens maybe once in 2 years. It would take me ten times as long to choose the welder than to make that (once in 2 years) weld. :laughing:
/ Miller Multimatic 200 #14
Ha, I kinda got the knack of the speed thing. It took a while. After a little thought I am probably welding more than 6 inches. At first I would cut all my pieces and then weld. If I had a lot of pieces to weld I started noticing really bad sputtering of the arc and porus welds after a few minutes of continuous welding. Thus the need for a bigger machine.
"Welding till it sputters" is the reason I bought a larger machine as well. :)
I bought a millermatic 210 mig about 10-12 years ago - an excellent upgrade.
(Millermatic 212 is the modern version)
Since then I've added 250 amp DC inverter stick/tig - light and lots of power.
Massive 900 lb AC/DC stick/tig that puts out almost 500 amps. Duty cycle at 230 amps AC tig is still 100%.
My advise is to compare the duty cycles in the amp range you plan to weld the most at. Look for 50-60% duty cycle in that range. My millermatic 210 was the smallest mig I could get with that restriction at the time.
/ Miller Multimatic 200 #15
We bought a Multimatic 200 6 weeks ago and so far love it. We have used it several hrs a day since we bought it .
/ Miller Multimatic 200 #16
Hi I have the miller vintage 250 wire feeder , the sales person asked me what I welded on before I said the miller o matic 200, he said that I would like the arc on the 250 and the nice thing it has a chart on it so set up is easy ,very happy with it.
2020 KENWORTH T270 SERVICE TRUCK (A59823)
2020 KENWORTH T270...
John Deere 7810 (A60462)
John Deere 7810...
Case SV280B (A60462)
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
17601CFL (A59228)
17601CFL (A59228)
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
