Miiler Machine
/ Miiler Machine #1
murphy1244
Super Star Member
Ohio
Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Have a chance to buy a Miller Welder and I need to know what its worth and even if I should buy it as being I never Welded before. Thanks for any and all.
Miller Dialarc HF Tig/Arc Welder
/ Miiler Machine #3
What is the output amperage? I think dialarcs were made in a few sizes. But they are tough machines.
I would check that the polarty switch works, and that it welds.
/ Miiler Machine #4
For a first and probably last welder, it is an excellent choice if the price is right! The last Dialarc 250 HF's were on sale for $1699.00 up here. It was around 1993. The first 2 letters in the serial number will tell you the year. H is 70's, J is 80's and K is 90's. Then A is 0, B is 01, C is 02, etc. If it works properly it could be worth around $750 if it has cables, foot pedal and TIG torch, etc.
It is based on a Dialarc 250 AC/DC but has a high frequency added for TIG welding. It is a very basic TIG machine and a decent stick welder. The school I went to had one to replace a Lincoln Idealarc TIG 300. There was something wrong with the Lincoln and no one could figure it out. The teacher was a very experienced TIG welder and I think his budget on a new machine was limited. He wasn't very impressed with the Dialarc HF for TIG. For stick it was decent but not as good as a Lincoln Idealarc 250. Miller discontinued the Dialarc 250 HF in the early/mid 90's when the Syncrowave 250 came out. It is a better machine but now it looks like the Syncrowave 250 is being replaced by a new inverter based machine. I saw some literature on the new machine and it is listed it as a possible replacement for the S/W 250.
/ Miiler Machine #5
Wow! Those prices on E-Bay are outrageous! They must be basing their price on the cost of a new machine but there is no new machine to compare them too. At best they are 20 year old machines and don't have square wave AC! They weren't legendary like a 50 year old SA200 to command the prices people are asking.
/ Miiler Machine #7
If you could get it for a few hundred I would say it's worth that just as a good stick machine. Much more robust than anything you could buy today for that price.
Do you definitely want the tig capability?
/ Miiler Machine
Mike, I never welded in my life. This one came up in a location search.
/ Miiler Machine
Well you could pick a lot worse machine to learn on. It would be nice to have a water cooler for it when you get into Tig welding.
Said it was missing a hose, was that for what your talking about? How high should I go?
/ Miiler Machine #11
I'm sure they mean a gas hose, I didn't see a regulator / flow meter either. Being as it's at an auction where you can't take it for a test drive first. I wouldn't go over a few hundred. But don't listen to me, I don't need any more welders. Only you know what it's worth to you;).
/ Miiler Machine #14
/ Miiler Machine #15
I love welding machines that pull a ton of juice, specially the ones over 600lb.
/ Miiler Machine #16
That Miller I sold weighed 800-pounds, and I had it hard wired to a 95-amp breaker.:eek:
This Lincoln is a 425-amp welder, and I have it on a 65-amp breaker. And it weighs 80-pounds. It will weld circles around that old Miller, well except the Lincoln doesn't have AC.
/ Miiler Machine #18
Yeah, that pretty much sums it up! :laughing::laughing::laughing::laughing::thumbsup:
/ Miiler Machine #19
The Gov't. doesn't even know the year of the machine they're selling.:confused3: The black face plate tells you right away it is a lot newer than 1976. JE is a 1984 machine. It's worth more than a couple hundred. In all likelihood there's probably nothing wrong with it so if you got it for around $500 would still be a good deal and it has the foot pedal. That's worth a couple hundred or more to replace. The only thing that could really affect it is burning 3/16" rods one after the other. The HF points may need to be adjusted but it would be a good machine to have. I saw on that link to other Gov't. machines someone was offering $400+ for an AC225/DC125 Lincoln which isn't even close to being as good of a machine as the Dialarc HF.
/ Miiler Machine #20
The older units had a lot higher duty cycle than the newer units. A new dial arcs are down to 35% duty cycle. I've used a good many older ones, and they welded really well. Probably an easy fix, even if something is wrong...but then, you can never tell. Looks decent for its age.
2013 Ford Transit Connect Cargo Van (A61573)
2013 Ford Transit...
TEST YOUR BID BUTTON! (A64276)
TEST YOUR BID...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
YANMAR 60" TILLER (A64280)
YANMAR 60" TILLER...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63688)
FRESHLY...
