MF35 stuck in reverse
/ MF35 stuck in reverse #1
FrankT
MF35 stuck in reverse..shift will not move...been advised to push on fork (through transmission fill hole) with screw driver or small crow bar. What part fork & in what direction do I push? Does it takle much force? dont want to break anything
/ MF35 stuck in reverse #3
Frank, the link JerryG gave is a good one, and tells exacatly how to correct the problem. Mine got stuck several years ago, and I freed it up. I was also nervous about putting too much pressure on the gears and breaking something else.
It takes a good size screw driver, or pry bar. It also took some trial and error - it's hard to see in that little access hole. Finally out of desperation, I gave it a good shove, and the gear moved where it was supposed to be. Have never had the problem since.
Good luck, and let us know if you get it fixed.
/ MF35 stuck in reverse #4
I used to have that problem, but it stuck in first. I would open the fill hole and with a heavy screw driver slip the fork back. I can't remember the shift pattern, but if you move the stick forward to go to reverse, you will move the fork forward to take it out.
/ MF35 stuck in reverse #5
Frankt, did you get your transmission freed up?
Bob
2010 New Holland Boomer 8N (A62613)
2010 New Holland...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
Atspower Mini Excavator (A60352)
Atspower Mini...
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
