MF3165 Alternator Type
/ MF3165 Alternator Type #1
superbrat123
MF 3165
I have a Mf3165 and I want to change to an alternator from the old Generator. Can anyone tell me what alternator and how to wire it up?
Thanks John
/ MF3165 Alternator Type #2
6 pr 12 volt genny? If it's a 6 volt, you will have to add a dropping resistor or change the entire system over to 12 volt. I'd suggest a one wire alternator the fits in the provided mount with a drive pulley that matches what you already have.
It's 12v. Thanks
/ MF3165 Alternator Type #4
Then any single wire alternator that will physically meet the dimensions and correct sheave size will fit.
Only difference between a single wire and multiple wire alternators is, a single wire will be internally regulated, a multi wire requires external regulation.
Yo will need to remove the external regulator (and there will be one) for the generator. Usually mounted on the generator itself.
/ MF3165 Alternator Type #5
I have always used ac delco for them cheap and readily available you can use the one wire self
Exciting or the three wire with plug
Just have to run a wire from key or oil pressure switch to excite alt
Tractor is almost as old as I am
/ MF3165 Alternator Type #6
Probably a good idea as there are a of imported (as in Chinese) alternators on the internet and far as I'm concerned, most all of them are suspect. I'm a Delco person as well
/ MF3165 Alternator Type #7
It's 12v. Thanks
the most popular alternators people switch to is a Delco 10si-se which is a one wire internal regulator alternator. I seen manufactured brackets for switching over to alternators on a MF135 on Ebay yesterday. their running around $35 bucks. looks like their all over ebay
1995 Freightliner FL70 Fuel Truck (A62613)
1995 Freightliner...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
Sakai SW354 (A60462)
