MF3165 Alternator Type
/ MF3165 Alternator Type #1
superbrat123
MF 3165
I have a Mf3165 and I want to change to an alternator from the old Generator. Can anyone tell me what alternator and how to wire it up?
Thanks John
/ MF3165 Alternator Type #2
6 pr 12 volt genny? If it's a 6 volt, you will have to add a dropping resistor or change the entire system over to 12 volt. I'd suggest a one wire alternator the fits in the provided mount with a drive pulley that matches what you already have.
It's 12v. Thanks
/ MF3165 Alternator Type #4
Then any single wire alternator that will physically meet the dimensions and correct sheave size will fit.
Only difference between a single wire and multiple wire alternators is, a single wire will be internally regulated, a multi wire requires external regulation.
Yo will need to remove the external regulator (and there will be one) for the generator. Usually mounted on the generator itself.
/ MF3165 Alternator Type #5
I have always used ac delco for them cheap and readily available you can use the one wire self
Exciting or the three wire with plug
Just have to run a wire from key or oil pressure switch to excite alt
Tractor is almost as old as I am
/ MF3165 Alternator Type #6
Probably a good idea as there are a of imported (as in Chinese) alternators on the internet and far as I'm concerned, most all of them are suspect. I'm a Delco person as well
/ MF3165 Alternator Type #7
It's 12v. Thanks
the most popular alternators people switch to is a Delco 10si-se which is a one wire internal regulator alternator. I seen manufactured brackets for switching over to alternators on a MF135 on Ebay yesterday. their running around $35 bucks. looks like their all over ebay
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
1968 MTTI Lowboy Trailer (A62613)
1968 MTTI Lowboy...
Mini Excavator Ripper Tooth (A66285)
Mini Excavator...
2015 Isuzu NPR-HD Box Truck, VIN # 54DC4W1B3FS807576 (A65563)
2015 Isuzu NPR-HD...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
