mf 1240 won't start
/ mf 1240 won't start #1
Corkinor
Massey Ferguson 1240
my mf 1240 won't start; the solenoid that moves the lever on injector pump does not move to run positiion when key is moved to on. any ideas on how to trouble shoot the solenoid? Thanks
/ mf 1240 won't start #2
Disconnect the solenoid and take an ohmmeter reading across the coil- should indicate conductivity (1-1000 ohms depending on coil size). You can also use a power supply (batter charger will work in a pinch, use low current setting) across the coil and see if the actuator moves when you apply a voltage.
Also don't forget to check the fuses.
Hope this helps.
Jeff
Thanks for the reply JPat; so I find I have power to solenoid; I will follow that up Cork
/ mf 1240 won't start #4
When you turn the key on, do you hear a pulsing noise?
I replaced the fuel shutoff solenoid and the tractor starts every time. I did hear a noise which I thought was the fuel pump. Thanks for the reply. Cork
MECHANICAL 4R48" FINGER TYPE SETTER (A64278)
MECHANICAL 4R48"...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
2015 Scag Turf Tiger 60in Zero Turn Commercial Mower (A64553)
2015 Scag Turf...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
John Deere 757 ZTrak Zero Turn Mower (A66285)
John Deere 757...
