mf 1240 won't start
/ mf 1240 won't start #1
Corkinor
Massey Ferguson 1240
my mf 1240 won't start; the solenoid that moves the lever on injector pump does not move to run positiion when key is moved to on. any ideas on how to trouble shoot the solenoid? Thanks
/ mf 1240 won't start #2
Disconnect the solenoid and take an ohmmeter reading across the coil- should indicate conductivity (1-1000 ohms depending on coil size). You can also use a power supply (batter charger will work in a pinch, use low current setting) across the coil and see if the actuator moves when you apply a voltage.
Also don't forget to check the fuses.
Hope this helps.
Jeff
Thanks for the reply JPat; so I find I have power to solenoid; I will follow that up Cork
/ mf 1240 won't start #4
When you turn the key on, do you hear a pulsing noise?
I replaced the fuel shutoff solenoid and the tractor starts every time. I did hear a noise which I thought was the fuel pump. Thanks for the reply. Cork
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2021 YANMAR VIO25-6A EXCAVATOR (A63276)
2021 YANMAR...
2022 EZ-GO ELITE...
