Meet Kermit!
/ Meet Kermit! #32
Very nice work and some good ideas. Shows off the versalility of the PT pretty well too.
Cliff
/ Meet Kermit! #33
Nice work, Gravy. I really like the two receivers on the quick attach plate. Very versatile. /forums/images/graemlins/wink.gif
/ Meet Kermit! #34
Gravy, how thick is the steel on the ditch scraper? Can you give me approximate dimensions? How is it holding up?
Thanks,
Bob Rip
/ Meet Kermit! #35
I came across something that you might can use to help with your welding. It is a magnifier lens that fits inside a welding helmet. Your local welding supply should have it. Just a couple of dollars. It helped me to see better. I use the automatic helmet. Good luck
/ Meet Kermit! #36
Thanks J.J.
I have stopped welding unless its a sunny day. That really helps me if it is bright. I have tried using spot lights with limited success. I will get the magnifer lens and give it a try.
PJ
/ Meet Kermit!
Bob,
The plate is about 5/16" - 3/8". I haven't used it much, but when I did it snagged some rocks pretty hard and doesn't seem to have bent. If it does, I'll add some reinforcement.
Dave
/ Meet Kermit! #39
Willl said:
Pajoube, what # lens are you using ?
Maybe a lower # might help.
So far I have not gotten any lenzes but have taken work outside in the sunlight which has really helped. Part is due to being a rookie.
PJ
/ Meet Kermit! #40
What number are you refering to, the shade number or the magnifier number.
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2014 Nissan Rogue SUV (A59231)
2014 Nissan Rogue...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
iDrive TDS-2010H...
2016 Lincoln MKZ Sedan (A59231)
2016 Lincoln MKZ...
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
