D2Cat
Platinum Member
- Joined
- Nov 6, 2014
- Messages
- 773
- Location
- 50 miles south of Kansas City
- Tractor
- Case730, Deutz 6206, Cat D2, Kubota L305, Kubota L4240, Kubota B7100HST, Kubota TG1860G, TG1860D
So what would cause an inch of sludge build up?
Also consider the way the engine was used. The A/C compressor cycles on and off according to the temperature needed inside the reefer. If the engine has long idle times it's not running hot enough to enable complete combustion.
If we use my 2200 watt inverter generator while hunting and run it all night to keep the cpap's going. At the end of 10 days there is a lot of sludge in the oil because it's cold outside and the load is nothing compared to what the generator can put out.
So this project is back on track, and my wife really sees the importance of getting it up and running too.
This is a very important point. This means that the project will definitely move along from now on.![]()
Have you thought about installing a set of Murphy gauges on your generator? Most engines that run steady in this area (irrigation/generator/oil field pumps) have them so that if something goes wrong the motor will shut down before any damage occurs.
Most tractors around here that see regular pto generator use have Murphy's installed too.
I don't mind the hours put on my tractor running my pto generator at all. After all, isn't that what I bought the tractor for ?, to use when it's needed...
IF, I felt like I was hurting the tractor any at all, running it for hours and hours, then I bought the wrong tractor in the first place!
SR
A good second tractor can easily be bought cheap, and is VERY handy to have around for other chores too, by the time you are done building that gen set, you will have more into it than what I have into my second tractor, and all you will have is a generator.
.....heat for my home; is really a steal. It would be silly not to do it.
It would be silly to not have a wood stove and a small generator that runs a few hours in the am and pm in my opinion.
Our generator uses a little over 4 gallons per day in an extended outage, and does everything we need it to do.
The wood stove runs throughout winter, power or no power.
Well, I paid $3,500 for the tractor and it had a thousand dollar Howard Rotavator on the 3 point.It would have to be a pretty cheap second tractor!
You probably missed the part about "being an engine kicking around", but it was literally that, a barn find. I would have to add up all the receipts to get an exact number as the little stuff does add up, but I am guessing I probably have $400 in the project as of right now. $179 is for the new starter, so not really a lot of money. When all is said and done, I figure it will cost me about $600 to get this running. That is pretty good because an engine of this size has a value around $4500.
A 20 KW Genset new would cost around $10,000, so this project, at $600, as back up power and heat for my home; is really a steal. It would be silly not to do it.
