Mahindra 100 hp tractor
/ Mahindra 100 hp tractor #41
/ Mahindra 100 hp tractor #42
/ Mahindra 100 hp tractor #43
From what I have gathered its exactly the same except for the loader. Just add Mahindra decals and markup and you have a mForce.
I've responded earlier with some differences, but I thought a few more details would not hurt. Advantages of Mahindra mFORCE compared to the similar TYM:
Larger lift capacity on the loader
18.4x34 Titan Radial tires on the rear. TYM uses smaller bias tires, as does the Kubota 9960 and JD 5101E I believe.
13.6x24 Titan Radial tires on the front. TYM uses smaller bias tires, as does the Kubota 9960 and JD 5101E I believe.
Sturdier design of front wheel dish.
8 bolt front hub. TYM uses a 6 bolt.
3 point hitch is a flex link style. TYM uses a claw hitch style 3 point lower links. (Much higher standard lift capacity VS JD and Kubota)
5 year 3000 Hour power train warranty with no deductible standard equipment.
#1 selling tractor in the world
Financing available from Mahindra Finance USA
So buying this tractor offers advantages and value beyond just a decal. But honestly, in a sense the decal has value of itself. Beyond the technical specs, you get the service support, parts support and financing support of Mahindra USA and it's growing network of dealers.
/ Mahindra 100 hp tractor #45
That's some good info Dave. I saw the claw design on the Tym and thought it was pretty neat with the ball inserts or quick link option. I do not know what the flex link is like on the Mahindra. Could you explain how it works? Thanks for your input.
/ Mahindra 100 hp tractor #46
The flex link is just a name for the typical extendable lower links, just like many tractors use today. This flex is especially nice on larger tractors with heavier implements, since it can be tough to manhandle a big heavy implement. Mahindra spec'd out the tractor that way on purpose. The claws are cool, and if they work with your implement then there isn't much of a downside other than occasionally losing a ball if you aren't careful. But the claw will occasionally not work on implements. If you have an implement with a clevis style hook-up that is in a shallow pocket or if the pin hole is just a little close to the implement, the claw will not work. It is just a little bulky in some cases. The 4510 and 7010 cabs we sold a few years back had the claws. I had to cut off the claws and weld on standard spherical links more than once. Sometimes you can modify the implement, other times you have to modify the links. But on the standard flex links, you hardly ever get into a fitment issue. I'm not saying it happens all the time, but it does happen.
/ Mahindra 100 hp tractor #47
First look at the new mFORCE tractor. The mFORCE comes with a 5 year warranty standard, like all Mahindras. Sales have been great and owners seem to be very pleased with the new mFORCE tractors.View attachment 298104View attachment 298105
Please point me in a direction to where I might be able to see some specs for this 100hp tractor. I do not see anything on the Mahindra website. :confused3:
/ Mahindra 100 hp tractor #48
Thanks for clearing the flex link up for me.
/ Mahindra 100 hp tractor #51
Here are a few pics of the Mfoce at the regional dealer meeting in Albany. Have to say it a nice looking tractor.
/ Mahindra 100 hp tractor #52
I have a 8560 CAB, but am very interested in the MForce. Where can I find all of the tech specs? I just looked at Mahindra website and did not see any. What are these selling for?
/ Mahindra 100 hp tractor #53
We probably won't see the specs listed on the website until Mahindra has ramped up production. Right now the tractor is available at just a few dealer locations. Soon (being vague as I don't really know when) the big tractor will be available to all dealers that are interested and setup and ready to sell into the ag market.
If you call your local dealer, he can get availability info and specs and prices for you. But he may not have it at his fingertips.
/ Mahindra 100 hp tractor #56
Thanks for the photos!:cool2: I love those cute front fenders.;)
Will there be an open cab version.:confused: Also, will Bradco/Mahindra make a hoe bigger than a 511 to match it?:thumbsup:
hugs, Brandi
/ Mahindra 100 hp tractor #57
As Dave said, they did give us some basic numbers but nothing firm and only availible in certain markets at this time and dealers that are set up to handle this size tractor and ag customer.
/ Mahindra 100 hp tractor #58
hugs, Brandi
They made no mention of an open cab. But it would be sweet if they maybe put a 14' or 16' hoe with curved boom with flip around seat to operate from the comfort of you climate controled cab and a hydraulic thumb would be nice too! But dont think thats going to happen.
/ Mahindra 100 hp tractor #59
I agree on all points.
/ Mahindra 100 hp tractor #60
Dang it.:( I would buy one if they did.:thumbsup: Guess I gotta go yellow.:rolleyes:
hugs, Brandi
UNUSED IRANCH MINI HYD AUGER SET (A60432)
UNUSED IRANCH MINI...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2016 Ford F-150...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
